I have a 2550L laserjet I am trying to drive it with a MAC. It does not respond to the "print" signal. Everything else seems to run ok
My HP laserjet 2550L is set on Amercan 'letter format' after a reset. I want to print on A4 paper which causes a problem after a few pages. If I change to A4 in the toolbox, on the surface it looks ok but...
Hello,if you are using Microsoft Word, check the page setup and printer settings in Word as you have the option there to change paper size as well as on the printer.
Hope this helps
nicam49
Jan 17, 2011 | HP LaserJet 2550L Printer
Did the Laserjet 2550L make duplex prints? if
It is called a manual duplexing option, the bottom rung of the duplexing ladder, you phisically have to take out the peice of paper after one side is printed, turn it over and reinsert it
http://www.retrevo.com/r/258bh050/38/Printing+on+both+sides+%28duplexing+manually%29#q=HP+2550L
Sep 09, 2009 | HP LaserJet 2550L Printer
HP 2550L low yellow toner -- can i still print just black???
Unfortunately if one colour is out, then you cant print. These cartridges contain a chip and once depleted will not print until a new cartridges is installed
Dec 12, 2008 | HP LaserJet 2550L Printer
HP Color LaserJet 2550L
select color settings in the printer properties on your pc
Aug 06, 2008 | HP LaserJet 2550L Printer
Printing problem
the problem exclusive between the drum or the fusser unit
Apr 25, 2008 | HP LaserJet 2550L Printer
HP 2550L Printing Problem
check to be sure you tool the strip out and that it's seated correctly
all the way down.
Dec 07, 2007 | HP LaserJet 2550L Printer
My 2550L stopped printing.
take it out and then put it back in.
Nov 05, 2007 | HP LaserJet 2550L Printer
12 people viewed this question
k24674
