Question about Canon Office Equipment & Supplies
Copy comes out dirty and ink comes off when touched.
  • bgarner985 Oct 05, 2009
    Thank you. :0)
    Scholar:
  • 40 Answers
If your copier uses toner and not ink then it sounds like you have a fuser issue. Your fuser heats up and through heat and pressure it causes the toner which is a powder to "fuse" to the paper. If teh toner is smearing off then the fuser will need to be looked at. There is eaither a heating element or a heating lamp that has burned out and will need to be replaced by a tech.
Posted on Oct 04, 2009
When printing label ink is mussin in stripe thru all labels. Does this mean running out of ink?
No, it's a thermal printer so it has no ink. A missing strip through the text means the printhead is dirty, clean it as per the manual. You can download the manual from the Dymo website if you don't have a copy.
Jun 14, 2015 | Dymo LabelWriter Office Equipment &...
Brother Printer-copy-scan-photo capture Model DCP-110C After replacing black ink and yellow ink, still says yellow ink low, and will just print out pink menu items, no message. I cleaned it 5 times. ...
place the printer cartridge into a small amount of water to make sure the yellow is flowing out. Let me know what this finds and try it again if yellow comes out.
Also, what exactly did you clean, the metal contacts?
Jul 03, 2008 | Brother Office Equipment & Supplies
Want to copy a document but coming out blank???
Check the obvious, first: inspect the glass of the copier's scanner for anything that could prevent the scanner from getting a clear image of the document that you wish to scan, & MAKE SURE THAT THE DOCUMENT'S PRINTED SIDE IS FACING THE SCANNER. Furthermore, make certain that the toner/ink cartridge(s) have been properly installed with the packaging tape & any plastic interrupter pieces removed. It could be out of ink or have a dirty/clogged printhead--which would require choosing a printhead cleaning option from the printer's maintenance menu.
Dec 03, 2014 | Office Equipment & Supplies
How to stop backgrounds being printed when i copy something
The optics are dirty.Use a flash light and look at the optics on the printer.I'm sure you will see their dirty.Remove glass ,Clean the mirrors in the scanner cavity with a moist cloth.Don't scratch or press to hard the mirrors are brittle.
Apr 09, 2013 | Epson Stylus CX9400 Photo Printer
Replace ink cartridge
If the ink cartridges are brand new and you get this error then take it back to the store and demand a replacement. If your ink cartridges have been running a while then chances are that they are dirty...
Gather cleaning supplies:
Clean distilled water. Use bottled or filtered water if distilled water is not available.
Clean cotton swabs or any soft, lint-free material (coffee filters work well).
Remove both cartridges.
Unplug the printer.
Lightly moisten the lint-free cleaning material with clean water.
Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty.
If that does not work then I would try ordering some new cartridges from a trusted source.
CANON PIXMA INK CARTRIDGES
Sep 12, 2012 | Canon PIXMA MP240 All-In-One InkJet...
When printing dark line down copy
A line down the copy can come from a dirty document scanner lens.
Usually white out or wet ink will smudge on the document scanner. Opening the document cover check the scanner for a dirty glass. Some document feeders have the white roller on top of the small glass window. They have delicate plastice retainers that hold the roller on both ends. Extra care needs to be taken if this roller is removed.
Clean the roller and the glass with wet towel. Shine a flashlight on the glass to see if there are anymore black marks on it.
Use the finger-nail to run across the glass and make sure no debris is on it. Even a spot can make a line on the copy.
Also, a bad fuser roll can cause a black line on the copy. A defective drum unit can cause a line on the copy as well.
If all else fails place a Xerox service call for this problem.
Oct 22, 2009 | Samsung Office Equipment & Supplies
Canon faxphone L80
The drum blade is leaking or is worn out. You need a new cartridge.
Jun 20, 2009 | Canon FAXPHONE L80 Laser
Light in color and won't copy dark. It come out light purple
you may try
1) color ink cartridge--- no enough ink or the cartridge ink channel dryer and constipated, refill ink and put down the cartridge bottom surface to water a little for 1 hr, then set back. or change a new cartridge if not fixed go next
2) print head--- the ink channel dryer and constipated, take out print head clean it's ink channel using cleaner or steep in water (do not touch circuit pin area with water) 20 minutes or longer. then set back and test (you can do more times), still not fixed, your print head have to change.
Feb 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP 920 Fax Half Lines
Try making a copy of something.
If the copy comes out the same way as your faxes, then the ink cartridge is either dirty or clogged.
You can try removing the cartridge and checking the bottom of it.
You can even wipe the bottom of the cartridge with some denatured alcohol.
If this doesnt work, then purchase a new cartridge and your problem should be solved.
Good luck.
Hope this helps.
Mac =)
Apr 02, 2008 | HP 920 Plain Paper Fax
HP psc 2110
Can be that the squeegy cleaners have got such a build up of ink on them that they arev making the contacts at the ends of the printhead too dirty; clean the contacts WITHOUT touching the printhead itself, or more ink will only flow out and lead to more build up.
Oct 22, 2007 | HP PSC 2210 All-In-One InkJet Printer
87 people viewed this question
old marine
old marine
