Question about Whirlpool LEW0050P Dryer
A FELT STRIP CAME OUT OF MY DRYER. CAN I STILL USE
A FELT STRIP ABOUT 1 INCH WIDE AND THE CIRCUMFRINCE OF THE DRUM CAME OUT OF MY DRYER. CAN I STILL USE THE DRYER? IT SEEMS TO STILL WORK FINE. I HAVE A AWZ 220 GD MODEL ELECTRIC FRONT LOAD DRYER.
  • 61 Answers
You need to reinstall it because that is what the drum glides on and in time you will hear metal on metal grinding
Posted on Sep 28, 2009
Leather strip came off dryer. Now seeing shiny fibers on clothes. I'm wondering what the fibers are and if they are dangerous. Dryer is a kenmore from the 80s or90s
The fibers are felt and theirself are not dangerous...however they were secured to that leather strap that came off and that leather strap and the felt fibers comprise the rear drum seal and now their is a gap in the drum because that felt seal has come off...with that felt seal off their is a great possibility of clothing falling through the gap and damaging the components of the dryer (and ruining your clothing)...it is highly reccomended that the felt seal is replaced on the dryer drum.
GENE
Sep 08, 2011 | Kenmore Dryers
I have a Kenmore Elite Oasis dryer and it is making a grinding noise when the drum is turning. I think a long fabric-like strip of (gasket?) was found inside the drum that may have worked it's way off...
Yes indeed their is a part exactly like that..it's a felt seal that goes between the drum and front&rear plates that support the drum. WHen ordering the part ask for a felt seal
GENE
Aug 27, 2011 | Dryers
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
There is a felt strip that came out of inside the dryer. it popped out from under the rim of the drum part. can i get a replacement part? it the dryer still okay to use?
Yes it is replaceable . Screws up into top from door opening 2 or 4. 2 screws into front from inside case into front . Lift up and out . Felt fits in groove around bottom of plastic frame and drum just rubs against it .
Oct 29, 2010 | General Electric DRSR483GG Dryer
I have a rubbing sound coming from the gas dryer drum
The rubbing sound is probably due to worn or missing glides around the dryer opening that the drum rides on. These are usually mounted on a felt strip that is glued to the front panel of the dryer. Remove the front panel and you will see this strip. It is easy to replace and comes in a kit with the glue. Make sure you clean the area after removing the old strip so the glue will adhere properly. If this strip and glides are in good shape, I would look at the bearing or rollers at the back of the drum and check clearance around the drum for rubbing. Hope this will fix ya.
May 06, 2010 | GE Dryers
Felt strip around front loading Kenmore dryer(M10201265) drum came out. Trying to replace it. Whats the best method to do so? The part listed for our model number seems too wide, but it could be we aren't...
If you are talking about the front seal it should be only able to fit one way, the ends are tapered. Possibly the wrong one was packaged in the bag, (been there done that) compare it to the old one and the instructions should explain if there was a modification or design change.
Eric
Jun 06, 2009 | GE DBSR453EBWW Electric Dryer
Brown marks on the clothes
Yes, the felts are what seals the unit and allows the drum to turn without much heat loss. The felt can become damaged and the clothes will get caught between the drum and the housing leaving these marks.
Apr 09, 2009 | Kenmore Elite HE4 Electric Dryer
Dpsr475gw0ww GE Profile Gas Dryer noisy
The felt seal should be replaced if it is bunching up. The squeak could be due to worn drum rollers in the rear.
Jan 07, 2018 | GE Profile DPSR475GW Dryer
Maytag dryer neptune felt at rear of trum came out
you have to buy a new one if the felt seal is still good use contact cement on the drub and seal to put back on with need any more help let me know
Jan 11, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Loose drum support felt
you could try using "Permatex" hi-tack adhesive.  you need to remove the door where the bearings are first.
Oct 13, 2007 | Dryers
Whirlpool LEW0050P Dryer Logo
241 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
