Question about E-Machines eMachines Desktop PC
Computer keeps rebooting - E-Machines eMachines Desktop PC
  • 3 Answers
AT SWITCH-ON ENTER 'SETUP' AND CHECK THE BOOT PRIORITIES. ENSURE THE FIRST OPTION IS THE DRIVE WITH THE OPERATING SYSTEM, USUALLY :C OR HDD-0. EXIT SETUP AND TRY TO REBOOT.
IF THIS FAILS SWITCH OFF AND THEN ON, ENTER 'SETUP' AND CHANGE BOOT DRIVE TO 'CD' INSERT OPERATING SYSTEM DISC IN CD TRAY, SOMETIMES REFERED TO AS THE 'RE-INSTALLATION' DISC. EXIT 'SETUP' TO CONTINUE BOOTING.
FOLLOW 'ON SCREEN' DIRECTIONS TO REINSTALL OR REPAIR OS.
Posted on Sep 28, 2009
  • 324 Answers
Your windows is corrupted so please reinstall the windows
Computer comes on and is fine for a while then just cuts off,then turn it back on then its fine for a while then cuts back off.
Hello
To start with, you should check all your hardware. A loose connection somewhere or a faulty piece of hardware could be the reason, the computer keeps rebooting itself. In case your RAM stick is not fitted properly, or is corrupt, the computer displays an error message on the screen and keeps rebooting itself. The same problem occurs with a hard disk. You can use 'Memtest86' to run a hard drive check.
You may at times come across an error message on your screen, like a system failure error, before rebooting by itself. There is a particular solution to this type of problem. You should first go to the My Computer icon and right click on it. Select properties, and a window will appear on your screen. Click Advanced tab → Start Up and Recovery → Settings. After clicking the settings option, you will have to uncheck the box next to Automatically Restart. Click OK twice. This will prevent the computer from rebooting itself and you can redress the issue.
A different way to tackle the problem of 'computer keeps rebooting itself', would be to restart your computer in the Safe Mode. Allow the computer to boot fully and let your windows operating system load fully. Now, if your computer keeps rebooting itself even in the safe mode, there is a problem either with the operating system or hardware. And if your computer is not rebooting itself in safe mode, the problem is related to certain software.
Over heating is another reason why your computer keeps rebooting itself. Not many people pay attention to this aspect though. The fan responsible for keeping the CPU cool, may be malfunctioning or there could be dirt settled between the fan and CPU. Any one of these could be the reason for your problem. Either clean the fan area, or replace it if necessary. Try providing proper ventilation for your CPU, so that it stays as cool as possible.
You computer could reboot on it's own if you have installed improper drivers. Right click on the 'My Computer' icon, and click on 'Properties' from the menu list which appears. A new window will open. Select the 'Hardware' tab, and click on 'Device Manager'. A list will be displayed on the screen in which you will have to check all categories. Is you see any red or yellow warning icons, make sure you update that particular driver from the internet.
Dec 13, 2010 | Computers & Internet
I have pcchips m955g motherboard, comp reboots during
If the computer keeps rebooting when you first start it up it is quite possible that the hard drive is broken. It keeps looking for the start up boot sector, but it's broken so it keeps trying again..and again...and well you know.
Hank
Nov 30, 2009 | Computers & Internet
My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Oct 06, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Had a power outage and now computer keeps rebooting. saw solution about going to my computer properties advance and unchecking automatically reboot, but cant' get there because computer keeps rebootin
hi
while rebooting u press the F5 key for a while, it will redirect u to a boot menu,in this boot menu u have some special options to boot like boot in safe mode,safe mode with networking ,debugging mode,last known good configuration boot,start normally,etc u first boot in safe mode and try to deactivate rebooting in ur own technicand u have more options try all of them it will be ok in 2 or 3 options
Thank You '
Dnt Foget to Rate me
Apr 21, 2009 | Acer Veriton M410-UF9500P Desktop
My computer keeps rebooting after if reaches windows xp logo
I also have this same problem about a constant reboot of computer and what I did is I replace the Power Supply and everything is already working , becauise this problem can be link in failing power supply already...
Hope that helps..............
Oct 05, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
Phillips go gear SA3245 reboots win 2k computer
You must have Windows XP SP2 or higher for it to work properly - there are no drivers, nor was it designed for earlier versions of windows
Jul 24, 2008 | Philips GOGEAR SA6045 MP3 Player
try to check if your IDE cable is plug-in correctly. insert it correctly. try to restart your computer.
Aug 10, 2007 | IBM TravelStar 60GH 60 GB Hard Drive
E-Machines eMachines Desktop PC Logo
114 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
