Question about Electrolux Vacuums
Electrolux model LX vacuum- Problem, ejects empty
Vintage Electrolux model LX vacuum- Problem, ejects empty bag, the blower works very well, but the vacuum suction is very limited. Is this repairable at a reasonable cost?
    Problem Solver:
  • 5 Answers
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Posted on Nov 22, 2009
  • Jon elux Nov 22, 2009
    Ok, I just found out more, from www.137.com, a guy who is much more of an electrolux fanatic than me. Apparently to address this problem on the early LX's without the control dial on the bottom there was a "basement and attic" key made by electrolux which would when put in place would clamp and hold the manual bag ejector button in place so if the automatic operation occured, it simply would not complete. (on the bottom of the cleaner near the side just below the letter "u" of the word "Electrolux". Electrolux suggested owners store the key, while not in use, in the tray under the cover where the cord plugs into the machine, just beyond the handle on the top, to open it, press the little button on the side of the trim, then while holding it in, lift the blue cover just above where the cord enters the machine. In some cases the key is still there, but in my case, it is not. I'm going to find out if my local electrolux man has one in his shop he will give me! Alternative is that you can disconnect the automatic system by unscrewing the inside of the bag door covers and removing them, inside you will find the automatic sensor system, there will be a short black or yellowish clear hose that attaches to the sensor, simply pull the hose off and the system will be cancelled. Replace the covers. But don't forget to change the bag as now it will be completely manual! Also, use Genuine Electrolux bags sold at your nearest Aerus branch or by the door to door salesman, you see on the LX the top and bottom of the front cover is vacant, and the suction is so good that using cheap bags causes the cardboard top of the bag to bend and gap and the seal between the bag and the cleaner is lost and full suction gets lost. You will see a rubber seal when you take out the bag that the cardboard rests on, if this seal is no good, you will lose best suction. The cardboard top on Genuine bags is much thicker to address this issue. Also, check to make sure your hose is not bad and leaking suction. Compare the air blowing out of the cleaner when you have the hose attached to the cleaner and cover the end of it completely to removing the hose and covering the hose inlet.with your hand. If the bag is a good one sealing well, you should have no air coming out the exhaust when your hand completely covers the suction inlet. If you get air when attaching the hose and covering the end of the hose, you have a bad hose and need a replacement. I do not recommend woven type, no longer sold new, but rather the rubber or corrugated plastic types. However, generic hoses sometimes the plastic fitting comes unglued and the hose comes out of the metal fitting, if this happens, reglue the hose with epoxy. Jon
My upright electrolux vacuum will not suction from the wand. How can I fix this?
HI, it's Jim from Crucial Vacuum!
If your Electrolux vacuum is losing suction from its wand then most likely there is a clog in your vacuums hose.
Stretch out your vacuums hose as far as you can to unblock any clogs. If there is a clog in a hard to reach spot try using a broom handle to reach the area.
Another area to check is your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction for your vacuum. Empty your dust filter after every use to promote optimization in your suction.
You can purchase replacement parts for your Electrolux vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=electrolux&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 08, 2015 | Electrolux Vacuums
Electrolux Ultraactive losing suction and turbo head brush won't spin. Canister is empty, no blockage in hose or nozzle of turbo head, filters cleaned, but Hepa not replaced recently. Could that cause it...
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try to fix the suction of your Electrolux vacuum. The first thing you should check is the height of your brush-roll. Your height setting may be too high for the type of floor you are vacuuming. Raise or lower your brush-roll depending on if you are vacuuming on carpet, tile, or wood surfaces.The second thing you should check is the vacuum bag. If it is full your vacuum can lose suction. This is simply remedied by replacing it with a new and clean bag. The third reason for a loss of suction is your hose is clogged. Check the hose for debris or foreign objects that may be obstructing the flow of air in the vacuum. The last potential reason for your vacuum losing suction could be the brush-roll itself. If it is clogged with dirt and hair it may not be spinning and not picking anything up. Check to see the condition of your brush-roll. If it is clogged remove the debris.
You can purchase direct your Electrolux replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/electrolux.html
Jeremy Lerner
Aug 05, 2014 | Vacuums
No suction from canister on electrolux guardian model c154e. green light on switch is on
Have you remove the hose and checked the suction at the intake of the vacuum? If the motor is running there will be suction.
If there's suction here, attach the hose to the vacuum, turn it on, and check the end of the hose for suction. If there is none or very little, there's a clog or bad leak in the hose. The easiest way to check for a clog is to drop a coin in one end, lift that end up allowing the coin to drop through to the other end and out. If it drops through, the hose is clear. If not, the easiest way to clear it is to plug the hose in to the exhaust port of the vacuum, place the other end into a large garbage bag or point it outside, and turn on the vacuum. This will usually clear a blockage.
Leaks that are severe enough to result in no suction will be readily apparent as tears, cracks, or cuts in the hose. A crushed hose will also result in the loss of suction.
If suction is fine at the end of the hose, do a visual check of the wands. It's unusual for them to be blocked, but not impossible.
Check the power nozzle above and behind the brush and where it attaches to the wand. The elbow can catch long objects resulting in a blockage.
If there don't appear to be any problems with the above mentioned items, you need to take the vacuum, with attachments, to a repair shop to have it checked. It may need a new motor, but that would be due to worn out or broken fans, and that is unlikely with Electrolux vacuum motors years older than that.
Dec 01, 2013 | Electrolux Guardian Bagged Canister Vacuum
The hose to our 2000 has broken. Where can we purchase a new one? Thank you for your time
CONTACT ME! Haha...I have hoses and tons of new and old vintage parts to repair the vintage Electrolux Vacuums. I believe in going green and sell a LOT of completely rebuilt ones as low as 25% of new price. mickeymackmark1@yahoo.com
Aug 22, 2011 | Electrolux UltraLux 2000 Bagged Canister...
How do you make it blow air out? trying to make air blow out,i have the hose that has controls on it. will work to **** up but when i put it to blow out will not come on.
The Guardian Canister vacuums have a blow port under the filter. So you need to remove the filter (on the Guardian Ultra, you have to open the top of the vacuum) by lifting it up the forward. Then disconnect the hose from the normal suction end of the unit and plug it into the blower port. Now turn on the vacuum. If the hose is clogged, position the other end of the hose at the suction port.
For the Guardian canister, select the high, medium or low force for the motor. Then blow the dust out from under the furniture or use to fill an inflatable. Turn off the vacuum and replace the hose in the usual position and replace the filter when done.
If you are still unable to get the unit to blow out when connected to the exhaust port after attempting to clear the hose, separate the hose, wand and handle. Look down the hose for any object that might be creating a one-way valve. Remove the foreign object.Do the same with the other parts of the unit. Also replace the vacuum bag. If the bag is sufficiently full, the airflow will be reduced through the bag to the exhaust and cause the problem you describe.
The Electrolux Guardian Canister Vacuums are part of the Aerus line. The manuals for the vacuums are available here: http://www.aerusvacuums.com/support/manuals/index.cfm . The Guardian Ultra is in the current model section. The Guardian is listed in the Older Model drop-down menu.
I hope this helps.
(many canister vacuums have a blower mode when you connect the hose to the exhaust (after the bag) instead of the suction side of the unit.)
Aug 17, 2011 | Electrolux Guardian Bagged Canister Vacuum
My Electrolux guardian C135 vac has lost suction. replacing the bag does nothing. removing the HEPA filter has no effect - what do you suggest? Will a replacement HEPA filter make any significant...
No you have a clog in the hose, wand or at the power head. Remove the hose wand and power head from the the vacuum. Turn on the vacuum, put the palm of your hand over the hole in front, you should feel plunty of suction. Then replace just the hose and put the palm of your hand over the end of the hose. If you do not have suction the clog is in the hose. You can try putting the hose on the blower port to blow out the clog or use the wire from a coat hanger. If you have suction, then add just the wand and repeat. If you have suction, then the clog is in the neck of power head, you will have to use a coat hanger to clear it.
May 08, 2010 | Electrolux Guardian Bagged Canister Vacuum
Model of BAg?
HI Your Exlectorlux uses Electrolux Style OX bags. Here's a few links back to our website to several different style of bags that will fit your Electrolux:
Genuine Electrolux Vacuum Cleaner Bags for Harmony Canisters
Generic Electrolux Style OX Vacuum Cleaner Bags for Harmony canisters
Hopefully this helped you! Please be sure to rate my repair helpful, or leave feedback if this was able to answer your questions.
Thanks,
Chris Jones
GoVacuum.com
May 02, 2010 | Electrolux Harmony Canister Vacuum -...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Pops open when bag still almost empty
try cleaning the filters if they are blocked then suction is lost and would appear like bag was full. hope this helps
May 20, 2009 | Vacuums
Vacuums Logo
553 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
