Question about Nikon D80 Digital Camera with 18-135mm Lens
Images have Black gradient at the bottom of every frame
When shooting with my Nikon D80, the image is black at the bottom. There is a dark gradient that starts at the bottom and fades as it goes up. It only started happening recently. The lens has been removed and cleaned. It's almost like a film fogging issue but there is no film obviously. It is also uniform on every image taken regardless of the lighting. Can you offer any troubleshooting assistance? Thank you in advance....
  • 291 Answers
This is most likely a dirty sensor inside the camera. Cleaning the lens won't help this, and you also can't see it if you look into the camera, since the mirror is in the way. You can look at the sensor if you take off the lens, put the camera in "M" and set the shutter speed to several seconds. Press the shutter release and look into the mirror. It will lift up and the sensor will be exposed. Make sure you are inside when you do this, and don't do it in a dusty or wet area. You may see a cloud on the sensor. If you do, then this is the problem. You can clean it yourself, but it's worth it to take it to a camera shop, and it's not too expensive.
Posted on Oct 02, 2009
  • 149 Answers
Problem in mirror lowered is broken replace
Posted on Sep 29, 2009
I have D80, in my display when viewing photo's any white colors are flashing from black to white. Any solutions?
You're seeing blown-out highlights. These are areas where you've irrevocably lost data due to overexposure. If too much of the picture is blown out, you may want to reduce exposure some and shoot again to preserve the data.
You can press up or down on the multiselector to change your view. The camera provides several different views of your images, including data, histogram, and, as you've discovered, highlights.
Feb 03, 2010 | Nikon D80 Digital Camera
I just got my new Nikon D80 but cannot get the LCD screen to light up. Where do I find the setting or the LCD screen to have it on while shooting pictures?
The D80 does not use the LCD screen to take images. The screen is only used to review images and use the menu system to check or change camera settings. When shooting, you need to use the viewfinder above the screen.
Nov 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 red and green streaking
check on the shutter speed and also the Aperture priority..
Jul 27, 2009 | Nikon SLR D80 Digital SLR Camera Digital...
My nikon d60 is starting to take forever to show the picture after taking the photo, and now all the sudden is shows a black box with shooting details on it, i can't get that off!
In your manual you will find how to change the display format (picture only, histogram, etc.). The time it's taking to display your image "might" be that your memory card is getting quite full and you're shooting large images. I shoot a D80 and it uses an SD card. Make sure you but a fast memory card if your camera does not buffer the inage before writing it to your memory card.
Apr 23, 2009 | Nikon D60 Digital Camera with 18-55mm lens
HOW TO SET UP THE D80 FOR HDR
Page 140 of your manual "Bracketing Programs" . This camera seems only to be able to do a 3 frame bracket. Normal , Over , and Under exposure. Set the auto bracket to (3) frames, set a 2.0 bracketing increment the order is not really that important. Normal however should be your first frame shot. Make sure that only the speed changes in the different exposures not the aperture this would lead to de-focused images. One you have the three images you will have to bring them into ©Photoshop or ©Photomatrix Pro to create your HDR file. The camera will not create this HDR on its own. there are plenty of HDR tutorials on YouTube. Use a tripod ond a cable relaes when you are shooting in order to reduce movement in you images.
Mar 20, 2009 | Nikon D80 Digital Camera
Nikon D80 Black and White setting
No, the B&W mode just saves time if you know you want it and is a "feature". You'll have far more control by taking in color (especially if using RAW) and then desaturating. With digital cameras the sensor is the same whether shooting color or using B&W mode...but the B&W mode is just discarding much of the information.
Jan 03, 2009 | Nikon D80 Digital Camera with 18-135mm...
Black & White shots from Nikon D80
You would be better off shooting in regular mode and converting to B&W using photoshop
Jan 03, 2009 | Nikon Speedlight SB-22S TTL Flash
Nikon D80 Camera
During shooting, or when the shutter-release button is pressed halfway, the number of images that can be stored in the memory buffer at current settings is shown on the exposure-count displays in the control panel and viewfinder. "r06" indicates that six images can fit in the camera's buffer, "r08" would indicate eight frames. Any other number could be displayed as well. Burst mode is used when you want to hold down the shutter button and continuously shoot. You are probably shooting in burst mode and your buffer is full, set the camera to single shot and see if that helps.
Jul 02, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
79 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
