Question about Nokia 1100
Need new oil bottle for wen electric chain saw model 1100
I have a McCulloch MS1415 electric Chain saw, and I can 't find the manual. What kind of oil goes in the saw, and how much?
There is bar and chain oil for lubricating the chain. Sometimes it comes in a small little bottle, but I have also purchased it in one quart size bottles also.
Aug 03, 2011 | Garden
Chain saw oil
Use regular bar/chain oil available from home centers, hardware stores, and saw dealers. Good luck!
Jun 06, 2010 | Electric Chainsaw Sharpener
Fuel mixture for MAC 3200 CHAIN SAW
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
May 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How do I put chain back on the Wen 14'' chain saw
Remove the chain drive side plate and remove the bar. Clean the drive area and inspect the drive sprocket for excessive wear. Run the motor for a short time to make sure that oil is being pumped out to the bar--is should just ooze out. Clean the bar chain groove and clean the oil holes at the drive end of the bar--especially the two small holes that go from the large oil holes out to the chain groove. Back off the chain adjustment screw several turns, then fit the chain over the sprocket (teeth cut toward you on the bottom) and then insert the bar into the chain and push the bar out till the chain is fairly tight. Apply the side cover and make sure the adjustment tang drops into the large hole at the rear of the bar. Install the mounting nut(s) to hold the plate and bar together. When run-up finger tight, turn the adjustment screw CW until the chain becomes tight enough that it doesn't droop from the bar, yet can be be turned by hand. Tighten the side cover nut(s) and recheck tension. If ok, run the saw for a few moments with the bar tip near some cardboard--it should throw off a thin line of oil. Keep the chain properly sharpened to reduce the chance of this occurring again. Hope this helps!
Apr 29, 2010 | Garden
What lubricant oil is used on the blade of a Wen electric chain saw?
I have a Wen 2000 10" electric chainsaw and just ordered a new chain, , but does it need oil poured inside? I have no manual. what kind and how much? can it be over filled, there is a black screw off knob that appears to be for oil?????thanks Kim
Apr 02, 2010 | Electric Chainsaw Sharpener
Oil cap for remington electric chain saw
Remington.com
http://www.desaparts.com/remington-chainsaw.html
You provide no model number. There are at least 3 different oil caps for different saws.
RemingtonPower is no longer in production. Replacement parts are mostly exhausted. Sooner or later the part you seek will be NLA. Sorry
Lou
Nov 03, 2009 | Remington Electric Chain Saw
Where can I find a new chain bar adj screw for WEN 3818 gas saw?
Most older chainsaw adjustments are visible when the saw is viewed from the end of the bar back to the saw. More modern ones are near the bar nuts (side). Lou
Aug 26, 2009 | Electric Chainsaw Sharpener
Sae 20 motor oil?
not for crankcase means do not use it as an engine oil in lets say a lawnmower engine
yes it is ok to use only as bar and chain oil and if it is a automatic oiler be sure it is oiling.
Jun 10, 2009 | Heavy Machinery
Wen electric chain saw -is it doa?
Are you pressing the trigger lock with your thumb before you pull the trigger? That's a safety feature to prevent accidental sawing.
There's not a sensor for the oil, but you don't want to run the saw dry. It takes a special bar/chain oil which is thicker than motor oil.
FYI... if you look for a manual on the web, search for "Wagner chainsaw" because Wagner bought the chainsaw business from Wen.
Mar 10, 2009 | Electric Chainsaw Sharpener
Nokia 1100 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
