Question about Dell Computers & Internet
HDD error no hard drive found, a new hard drive was installed but the result was the same
  • 3,940 Answers
If system has a SATA HDD and you are using WIndows XP, you may need to load a SATA controller driver before the HDD controller will be recognized by the Winodws setup. Windows XP will require the driver from a floppy diskette, Vista will load from USB or any other type of drive
Posted on Sep 29, 2009
My hp desktop says internal hard disk not found how do i reset my drive
First reset the CMOS. Check your motherboard specs for how to do this or remove the small round silver battery from the motherboard; wait 30 seconds and reinstall it. (It is a good idea to replace with a new battery.) This will reset the CMOS. Then reboot to see if HDD is detected. If not, go into the BIOS setup (repeatedly hit F10 at HP logo screen) and check to see if your hard drive is listed. You may have to set it to "on". If it is listed in BIOS, but not detected another drive (a bad one) could prevent it from being detected. If you have any removable or external drives attached to your computer, disconnect them. Reboot your computer to see if your HDD is detected. If not, open your case and disconnect the data cable from all drives except your primary hard drive. This includes the floppy, optical, zip, backup, or secondary hard drive(s). If your HDD is detected, reconnect each drives data cable one at a time rebooting between each. If after reconnecting a drive and rebooting, your HDD is not detected the last drive is a bad drive and preventing your HDD detection. I have found that sometimes a bad drive that is connected will let the HDD be detected then on later boots the HDD will not be detected. Also it is possible that your BIOS is corrupted. Let's hope not. Another possibility is a bad motherboard. I hope this helps you.
Aug 11, 2012 | HP Computers & Internet
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
Model : WD10EAVS HDD Fault : USB cable was accidentaly removed from port while hdd was connected. Problem : wd hardware found ,but no drive letter. Tried : New external case (same result),tried on...
Hello, Since you have tried all this and to no avail, i think you should change the circuit board, go to http://www.onepcbsolution.com to get a new one and fix it. Regards
Nov 26, 2010 | Western Digital Elements powered by WD 320...
Cannot boot from Momentus Ultra ATA 160 GN HDD
it can only clone the windows files and folders there is other files located on a hidden system on the hard drive, when you install and new hard drive these file are fixed to the drive. to make a bootable drive you need to install these files from a windows disc then add clone files over the top so these files don't get deleted.
May 27, 2017 | Seagate Momentus 5400.3 Hard Drive
How to install xp in hp dv 2918tx laptop
This is a Vista laptop with a SATA hard drive. Windows XP does not have the SATA drivers, you therefore must slipstream the drivers to a new installation disk
Mar 11, 2009 | HP Pavilion dv2000t Notebook
When powering up my computer, I get a failure. Primary hard drive 1 not found Strike the F1 to continue F2 to run the set up utility. I think the power supply fan is not working. What do I do?
your system can not detect your primary hard disk which host the operating systems,so you check the data cable to the hard drive and the power supply to the hard drive for supply
Jul 19, 2008 | Computers & Internet
Compaq presario not working
This generally indicates hard drive failure. Try reinstalling your operating system, if you have any problems during or after the install, then the hard drive will need to be replaced.
Jul 08, 2008 | Compaq Presario V4000 Notebook
Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
May 18, 2008 | Computers & Internet
How can i installed driver of sata hdd for linux red hat
if you are installing red hat 8 and higher there is no need to install extra driver because linux is the only operating system which will install everything including drivers, office suite,programming tools etc .... as far as my suggestion dnt install old versions of linux instead install new version ... there are many linux available
ex: fedora core 4,5,6 ,knoppix live cd linux ( which boots linux from cd no need install it) ,ubuntu,red hat,mandrake,suse ....
you can download it from net 4 free as linux is open source 4 all ...
be careful while installing linux especially during partitioning..... if u make a mistake you will lose all datas
Feb 04, 2008 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Computers & Internet Logo
273 people viewed this question
Alun Cox
