Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
DISHWASHER. M0DEL # C97873320-2, HYDRO MASTER
AT END OF CYCLE THE DETERGENT IS STILL IN THE CAVITY YOU PUT IT IN AT THE START OF THE CYCLE AND THE DOOR IS OPEN. LOOKS LIKE IT IS LATE OPENING. COULD IT BE THE TIMER.
  • slapjacks Dec 06, 2008
    The cavity door on our machine is opening but the detergent is caked and not dispensed. Seems that water is getting in before the dispenser opens. Is there suppose to be a little v-shaped notch in one of the walls of the detergent dispenser? It doesn't seem there should be since the rubber gasket on the dispenser lid is intended to make a water-tight seal against the walls of the dispenser cavity.
    Novelist:
  • 148 Answers
Run the machine with the cavity closed, but no detergent. see if it is open at the end. if it is, then its probably being overfilled or has enough residual build up on the pivot mechanism that it wont open. also, wash water may be getting to the detergent before it opens and then it cakes up and swells against the cavity door and impedes the normal opening event. you can check for clearance when the cav door is closed.
it is not likely the timer. running it empty will be a good way to know. it is released by an electrical mechanism. if the wires are damaged where they feed through the bottom of the unit into the door, it would be a reason it does not work. otherwise, the mechanism or electromechanical mechanism could be replaced as it is likely many times less expensive than timers. usually.
mark
Posted on Dec 22, 2007
How do I put detergent in I've tried dishes don't come clean
Dear Forrest.
Next time you run the dishwasher, open it whether in the middle of a cycle near the end, or immediately after the cycle is finishes, and see if the water is really hot
. If it is not, likely the powder detergent is not "melting".
Usually they need really hot water to "melt " the powder and clean the dishes.
Or use a liquid detergent, and be sure to use just a little to start.
One more thing.
Really "hard" water has minerals in it that will show up on your clean dishes, so perhaps you may have that problem.
Is this problem new to you?
God bless your efforts.
Jan 01, 2016 | Dishwashers
Ariston Dishwasher Detergent dispenser
you have 2 options.replace the timer on the unit or when you start a load wait 10 minutes and put a half cup or a little more of detergent into the water in the dishwasher.
Jan 05, 2008 | Ariston Technologies LL64WNA Built-in...
When I put detergent in dishwasher and turn it on, it seems to go through the cycles, but when it stops, the detergent is still in the detergent bin and the dishes are not clean.
Assuming the detergent dispenser door does open, it is likely the water is not reaching the top arms. Put a cup in normal position on the top rack and see if there is any water in it at the end of the cycle.
Likely causes are blocked arms or water distributor or the wash impeller is not working in the pump. The dishwasher uses the same pump motor for wash and drain cycles. You can check this by hearing if the water is getting swashed around when the wash cycle is on.
Check the impeller and water feed as shown in this diagram.
Hope this helps.
Jan 19, 2011 | Tappan 18 in. MDR251RE Built-in Dishwasher
White powdery film is on dishes at end of cycle.
Too much detergent. the amount of detergent should vary with the amound of soil left on the dishes. Most users will pre wash their dishes in the sink, but still use the full recommended amount of detergent. There is no soil for the detergent to bind with, so it builds up in the pipework of your dishwasher. when the water evaporates during the drying cycle, the detergent residue is left behind on your dishes. Run a cycle or two with your dishwasher empty. add a cup of white vinegar to each cycle, but dont add any more detergent. After that, cut your detergent amount by half, and see if your issues go away. if not, please post the model and manufacturer of your dishwasher.
Nov 18, 2010 | Dishwashers
I put washing up liquid in mu cda dishwasher now it wont do anything it wont rinse
If the machine cavity is full of suds, use a 'wet-or-dry' vacuum to remove all of the suds possible, then run a washing cycle without dishes or detergent to flush the machine. With luck, the machine will be back to normal.
Feb 08, 2010 | Electrolux 23 in. ESL624 Built-in...
Standing water in bottom of dishwasher
The first thing to try is to clear out debris from strainer area, you may need a Philips head screw driver for this. Clear out and then attempt to put the unit through its cycle.
The second thing I would try, is unattach drain hose from drain to sink, either blow in it or use a blower side of shop vac to force air into the hose. Reset dishwasher, and try again.
Not knowing how handy you are, you can pull the dishwasher out, please turn off circuit before doing so, also make sure you have towels handy. Unattached drain hose at base of drainage pump. Clear out hose and remove debris on bottom of pump. Reattach the hose and run through cycle..
If these do not work your issue is with a bad pump.
If there is a
Oct 13, 2009 | Dishwashers
Soap cup still has soap at end of cycle, but cup is open
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 25, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Westoint Dishwasher
Hi jannewbery,
I'm Harvey the Master Plumber.
Your problem is: You have looked in the manual under troubleshooting tips, but didn't find anything on the problem. The dishwasher goes into cycle,but during the wash cycle it stops,makes alarm and the wash and rinse ligts come on. And now you can't even find the product on this site.Westpoint Dishwasher WQP12-9240.
Thankyou Your dishwasher is stopping at stage 2 of the programme after beeping once. Quite often the detergent flap doesn't open. Am at your wits end and threatening to leave home!!!! The machine is less than a year old. PLEASE HELP!!!! Thank you.
Don't leave just yet. It sounds like a control problem. The d/w should still be under warranty if it is less than one year old. Use it before it runs out. I don't recomend this type of repair for the average homeowner.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 21, 2008 | Dishwashers
GE Triton XL
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Aug 28, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Maytag model mdbtt70aww. After the end cycle. open the door and found detergent tab on the bottom and the main wash cover is opened. Maytag diswasher model MDBTT70AWW. Put dishes and so...
Check both arms are spinning freely when you have the machine loaded up normally.
If thats ok you could try powder instead of tabs if they are not disolving correctly
Apr 05, 2017 | Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
129 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
