Question about Kenmore 22422 Top Load Washer
How to take off the agitator on my kenmore washer mod 11094572200
On my kenmore washer i can't seam to get the agitator off. i have taken that little screw out that was in the side of the agitator's shaft then i tried to pull it off, but it won't come off ...
my washer is leaking from the bottom where the shaft runs up into the drum, im thinking it's the gasket rings that needs replacing but i can't
tell untill i get the agitator off...help!!
sign no more clean things
  • 61 Answers
If its a older model remove cap on the vary top on the agitator it is a screw under there
Posted on Sep 28, 2009
Kenmore washer does not fill first ,goes right into washing.Replaced timer ,same problem.
Hello Sue,
The reason your washer starts agitating instead of filling first is shortted water level sensor switch that should be replaced.
The part number for that switch is W10177795
GENE
Nov 11, 2011 | Kenmore Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
if the motor runs than it is just a belt,not a big deal to install
be carefull because the new ones are direct gear connect and it is a bit harder to place the warn off plastic gears
Apr 21, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore mod 110 agitator turns while water fills tub
Check your pump and drain for a blockage.
You also could have a timer connection issue. Remove the timer wire connectors and reattach them.The timer simply has a quick connection block, sometimes they get a little loose and all you gotta do is push it all the way back in. Check for a loose lid hinge and safety switch also.
Feb 09, 2009 | Kenmore 24032\24036 Top Load Washer
I have a kenmore 110 238 121000
remove agitator cap remove bolt in middle of agitator top section will pull of replace the 4 dogs (slightly off white objects whirlpool part # 80040)
Dec 22, 2008 | Roper RAB2121KW Top Load Washer
Kenmore 22422 Top Load Washer Logo
294 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
