I my tv on then, it pops and turns itself off right after, any ideas?
  • 11,896 Answers
Very common power supply failure. These power supply's have cheaper made capacitor's in them that wear out and overheat quickly. They are not too awfully expensive to replace.
Posted on Sep 28, 2009
RCA L37WD12 LCD TV. it turns on and works perfectly with good picture. sometimes it just turns off by itself. sometimes it flashes rapidly before turning on. sometimes when you turn it on it just turns...
IF YOU CAN SOLDER YOU CAN FIX IT look for Bad capacitor 2200uf 25v if you see any that are puffed up on top they are bad. CK out Encompass Parts online 1-800-638-3328
Dec 08, 2009 | Televison & Video
A 2 inch wide blue line just came up on the right side on our screen. It goes from top to bottom. The model number is mu42pm12x. The weird thing is that it happened right after the remote (which is...
hmmm...when the remote was bumped, as in stepped on, perhaps? or dropped? the tv itself would be unlikely to be affected in the manner in which you mention, due to this.
unplug it and let it set for 20 min, then report back here, please..
May 23, 2008 | LG Televison & Video
TV popped very loud, then a green light blinked off and on. Then the red light (lamp) blinked off and on. Then the TV reset itself
I'm confused. Is the TV still working or not?
Pops can come from the CRT's tubes themselves. If a large enough pop then it may be that the CRT has imploded. When this happens the TV usually doesn't turn itself on again or is able to be powered back on.
Sony is a very servicable TV. They have carried parts for over 10 years. A good Sony Repair shop can fix it.
Blessings,
A/V Media Guy
Nov 20, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
I get a pop up sign on my set that states..."The system is experiencing above normal temperatures. Unless corrected it will shot itself off..." The TV is next to an A/C vent. I have it off for 8-12 hours...
This seems it could be a temperature issue either the temperature sensor is malfunctioning or the cooling fans aren't spinning at the right speed or not spinning at all. It would be best if you check the owners manual and look for the system reset feature, this may work, or the other option would be to hit the reset button.
Jul 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Insignia lcd 37''powering off and right back on by itself!
Hi Ed,
Since the TV is less then a year old and still under manufacturers warranty, I would suggest to take back to the vendor to get it fix because this LCD behavior is not going to get any better.
The failure on this TV is related to a power supply in most cases if the TV is turning OFF by itself or needs to be unplug to let cooldown and it works afterward.
Feb 28, 2009 | Insignia 37" LCD Flat-Panel HDTV
Audio Menu keeps popping up
There are probably some failing components in the uPC control area, or with the keypad board on the TV sets front panel. It is also possible that there is a problem with the filtering of the distributed power through the circuit boards of the set, and there is some noise causing a false trigger of the function.
This type of fault can take some time for the tech to figure out, unless it is a published common fault with the particular model of set where they give a list of parts to change.
Jerry G.
Dec 04, 2007 | RCA F36676ET 36" TV
Turns off on its own with a pop sound and is blowing a fuse
90% it is convergence board problem. Need to replace STK392-110 IC.
Sep 16, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
RCA has no sound
well u have a problem in the audio circuits of the tv which includes the speaker itself. but most of the time the audio power output transistor or ic get easily damaged resulting a no sound tv. if u dont have any idea with regards to this, i suggest have it check with a qualified service technician. it will not cost u a lot for sure.
Jan 17, 2007 | RCA F36665 36" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
