Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
One of the recievers does'nt open a channel to the
One of the receivers on my T9550 series does'nt open a channel to the other, cuts out before a transmission
  • Motorola Master
  • 1,654 Answers
Here is a link to the manual http://www.giantintl.com/ContentManage/manuals/Moto/T9500%20FINAL%20-%20English%20only%20all%20rights%20reserved%20and%20call%20center%20email%2004-24-07.pdf
Check your frequency, interference eliminator code and Qt filter to see that they are all set identical on all the radios. Also, in the case of cutting out before a transmission, this can be a sign of a bad battery. It takes more energy to transmit than receive, so you will see failure on the transmit side first. Try a known-good battery to see if it solves the problem.
Posted on Sep 29, 2009
Left channel cuts out, if i tap the reciever it will come back on.
sounds like the controls are dirty...or possibly the solder connection on the volume control has become intermittant...you can goto your local electronics store(or Radio Shack) and get some contact cleaner..open the unit up and clean the volume control as per the instructions on the can...make sure when you spray the cleaner into the control you turn it back and forth several times...then you want to spray more in to flush out whatever debris may have been in there...be careful not to get any on the face plate as it may damage the finish...also , make sure that the chemical spray that you use is safe for plastics...If this doesn't fix it , then the volume control assembly may need to be resoldered.
Mar 01, 2012 | Sony STR-DE185 Receiver
Picture/audio problems on my HDTV
This is a cable box problem. Could be a lack of signal stregnth or bad HDMI output.
The SA boxes have a very bad history of this, try using the component video output and see if the problem persists.
The HDMI is a real glass jaw of those boxes; but this problem could absolutly be your incoming signal...high def channels require more signal strength and that is what causes audio drops, pixilation and flicker.
If it was the HDMI in the receiver/tv you would get:
- Black screen, Pink fuzz or green streak dropouts.
- "Fireflies"
- Audio cutting in and out
- Not pixilation!
So what is my approach? If the box is rented or under warranty get it replaced. If the problem persists then call your cable company and arrange a service call at their expense.
If the box is not under warrenty go ahead and call the cable company and complain about a poor signal. If the signal is good, use the component video output...it looks almost identical anyway.
Let me know if this helps,
Cheers!
Feb 03, 2010 | Sony STR-DG820 Receiver
Power cuts off periodicly
Maybe. Try a larger guage extension cord.
Jun 11, 2009 | Sony STR-DG820 Receiver
Audio cuts out on my reciever
Try selecting any option for decoding priority from "auto" to "pcm."
May 09, 2009 | Audio Players & Recorders
Sennheiser em100 g2 receiver passes major static to mixer
This is a well known problem with the EW100 series that is easily solved.
You will need to run this reciever into a line input via a mono(TS) jack to jack lead. this will bypass the phantom power.
Make sure that you set the AV OUT to +18 in the reciever menu to get optimum level.
Phantom power is only present in the microphone inputs XLR3.
Hope this helps.
Rus.
Mar 01, 2009 | Sennheiser EM100G2 RACK MOUNT G2 RECEIVER...
I'm getting cable channels but no high def
Your TiVo is only recording basic cable (i.e., channels it can receive without a cable box). You will need a digital cable box from your cable company to record channels above 99. If your TiVo is a Series 2 you will not be able to actually record in HD either. You should be able to record the HD channels from the cable box, but they will not be HD quality. (This is my current setup and while the picture quality is much better than basic cable, it pales compared to bypassing the TiVo and watching HD directly off the cable box to the TV.)
Dec 23, 2008 | Tivo Series2 TCD649080 Video Recorder
Samsung LN-S3251D intermittent sound problem
Try to check the connection from your HD reciever it could be a loose signal from the reciever that why the sounds cut out..
Tell me more.
Thanks
Feb 19, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Hook up problems
either cut an rca cable and splice it to the speaker wires (not easy because the rca cable is coax type or buy rca ends from radio shack and do a little soldering
Jan 02, 2008 | Sony STR-DE835 Receiver
Popping sound from speaker when changing channels
This noise is normal with the cable box unless you set the cable box on HDMI sound
Dec 26, 2007 | Bose 3 2 1 GSX System
Sony STR-DE945 5.1 Channels Receiver
Hi, Happened across this forum looking for some remote info. Had a similar problem with my 945...main speaker outputs started to click off & on, no rhyme or reason. Found that the solder joints on the speaker output relays were cold (poor soldering). Actually happend twice, two different relays. Took me a while to find it, reflowed the solder, that solved the problem, over two years ago now. Are you able to dig into the receiver? Do you have a (good) soldering iron and some solder? If not take it to elec. shop and tell them to look for cold joints on the relays.
Jan 07, 2007 | Sony STR-DE945 Receiver
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
97 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
