Question about Starlite Next Play Clock Radio with iPod Dock NP105CR
The display is too bright at night. anyway to dim
The display is too bright at night. anyway to dim the brightness? (my old ipod player had a dimmer switch)
  • 5 Answers
Sorry this one was not built with any dimmer opportunities.
Posted on Oct 19, 2009
Which fuse is for the instrument panel back lighting?
Does the radio play ? Are any other back lighting components not lighting ? Does the HVAC control panel light up ? You probably need new radio !
The second interior lighting group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination, LED illumination and incandescent lamps.
When the ignition switch is turned to the RUN position, the radio VF display turns ON at maximum brightness. When the park lamps are ON, all incandescent and LED back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. The panel dimmer switch potentiometer is an input to the body control module (BCM). When the driver selects a dimming setting by moving the I/P dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Dose
Jul 14, 2015 | 2008 GMC Sierra 1500
Why doesn't the display change when I press the dimmer button
Dimmer may have been damaged from a power surge or excessive electrical power source. Could be expensive to repair, and be prepared if you need to have it serviced.
May 10, 2014 | Audio Players & Recorders
On my 1999 Olds Intrigue I have never had to turn on my lights at night. All night time driving lights come on automatically until recently. Now only the headlights come on.To get the dash lights,tail...
Without testing i would say you have DRL control module problem , But that would just be a guess .
In the night mode, the DRL ambient light sensor senses darkness. Then, the DRL module turns off the front turn lamps and turns on the headlamps through circuit 10. The DRL module also turns on the park, side marker, license, and tail lamps. If the engine should stall with the DRL control module in the night mode, the DRL control module will turn off the headlamps and leave the side marker, park, license and tail lamps on while the engine is being cranked. The headlamp switch operates as usual.
The Daytime Running Lamps (DRL) control module is designed to automatically operate exterior lights depending on outside light conditions. The DRL control module operates in two modes, the day mode and the night mode. In the day mode, the DRL ambient light sensor senses daylight. Then, the DRL control module turns on the front turn lamps (non-flashing) if under the following conditions:
• The ignition switch is on.
• The headlamps switch is in the OFF position.
• The park brake is released.
The brightness of the Vacuum Fluorescent (VF) displays is controlled by two signals: the park lamps on signal (circuit 230) and the VF dimming signal (circuit 308). With the park lamps on, the VF display of the radio, heater, A/C control (with RPO CJ2) and the instrument cluster will dim for nighttime viewing. When the park lamps on signal is not present (park lamps off), the VF displays are at high brightness for daytime viewing. When the park lamps are on, the I/P lamp dimmer switch provides a signal (VF Dimming Signal circuit 308) which controls the brightness of the VF displays when the I/P lamp dimmer switch is adjusted.
Do the Daytime running light's work ?
Nov 18, 2017 | Cars & Trucks
Display light not working. can't see time at night
From the manual:
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To select a backlight setting, press the Snooze/Dimmer Bar until the desired brightness is reached.
Dec 01, 2013 | Timex T309TT Clock Radio
How do i reset to factory settings?
hi
make sure the AC adapter is plugged in to the netbook and into an wall outlet that works . the dim indication tells me that there is power diminishing while the ipod takes more power from your computer .
Feb 05, 2012 | Acer Aspire One D260 Netbook
We have changed the dimmer switch, but when I have to change my lights from dim to bright my lights go out. This was happening before we changed the dimmer switch, but was not as bad. Last night when I had...
I had a similar problem with my Camry that the light will go out when I go from dim to bright. I found that in the dimmer switch contacts there is a small plastic piece that runs through one or two contact to operate a set of contact. Mine was broken. Seeing that you have a new switch it could be that yours are maybe not correctly in place - that is if it works the same as a Camry's.
Jan 31, 2012 | 2006 Dodge Grand Caravan
IPOD CANNOT DISPLAY LIGHTING
It is possible your player works correctly but some display setting causes no lighting. Try this procedure to set the screen brightness:
Choose Settings > General > Brightness, and then use the Click Wheel to move the
slider. Moving it to the left dims the screen; moving it to the right increases the screen
brightness.
I hope your problem was this only, if not I am sorry.
gylacz
Feb 24, 2011 | Apple iPod nano
Dim Screen on the 2001 Toyota Prius
Yes the screen dims automatically when the lights are on to suit night driving. I am not specifically familiar with the 01 model, however on my 08 model, the display brightness is also manually adjustable via a button located below and to the right of the display. The button is marked with a series of short lines assembled in an arc. Hope this helps.
Nov 25, 2009 | 2001 Toyota Prius
The headlights only work on Bright. The dim
If the low beam head light relay is fine,and the dimmer switch checks out fine,then look at the out put wire from the dimmer switch to the head light relay,check for voltage,then check the relay to see if it energizes.Then follow the wire(out put)from the relay to the head light.Now if power from the dimmer is getting to the relay,but the relay is not energizing,look for a bad relay,or bad relay ground wire.
Oct 30, 2009 | Buick LaCrosse Cars & Trucks
Starlite Next Play Clock Radio with iPod Dock NP105CR  Logo
387 people viewed this question
Top Starlite Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Starlite Audio Player and Recorder Expert? Answer questions, earn points and help others
