I want to add a VHS/DVD recorder to my TV. I have Cox cable. How do I get it to show my DVD's on the TV?
  • 4 Answers
Have you got scart sockets on the back of tv if so get scart leads
Posted on Sep 28, 2009
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
I have a apex tv and a dvd/vhs recorder, with a cable from wall only, how do I install
If you wish to record (VHS) off cable :
First connect the co-ax cable from the wall to the input on the DVD/VHS , then connect a second from the output of the DVD/VHS to the input of the TV.
You will need to match the channel (3/4) output and input. There should be a switch on the back of the DVD/VHS.
Tune the TV to channel 3 or 4 to match, To watch DVD/VHS .
Channel selection will be with the DVD/VHS when it is powered on.
TV will tune to channel when the DVD/VHS is off.
Jul 06, 2012 | Televison & Video
I have just bought a 40 inch HD LCD TV, I want to purchase a combo VCR/DVD HD to be able to record channel 11(the new free to air channels HD). Big W gave the model No. RC 689 D to me but they were not...
The VCR/DVD combo that you purchased will be able to record what you wish to a VHS tape at low quality or to a DVD at a higher quality.
  1. Coax cable (round and screw on) from the antenna to VCR/DVD
  2. Coax/AV/HDMI cable (only need 1) from the VCR/DVD player to TV
  3. TV on and turned to the input matching the cable you used in step 2
  4. Turn on VCR/DVD and use the remote control included with this unit. Not the TV's
  5. Turn it to the channel 11 on the VCR/DVD
  6. Put in a VHS tape or DVD-R to record onto
  7. You will be able to hit record whenever the show comes on or used timed recording in the menu to schedule it ahead of time
Sep 14, 2011 | LG RC389H DVD/VHS Recorder
Can I record DVDs from a Sharp 13VT-N100? The only connection source is the coaxial antennae port. There are "In" sources so I can watch DVDs from a DVD player but how can I reverse that so I...
Recorded from tv shows to DVD Disc have to hookup AV RCA component cables to both to Tv and DVD recordable player model connections together.Yes,u will able to recordable VHS tapes to DVD Discs.But ur DVD player model u have it is must be a recorderable DVD player model?Not just a DVD Discs and VHS tapes player only model.Check ur owner manual all are in there.
Aug 20, 2011 | Sharp 13VT-N100 Combo
I have a new vhs dvd player recorder that will not record.
please note in your vhs dvd manual it tells which dvd (maxell, tdk etc.)are compatible with the recorder
okay do you have a cable/satellite box connected to tv/monitor? yes or no
yes- is the the tv on ch 3? cable connected to cable box in, cable box out connected to dvd in,(on dvd set up menu make sure broadcast is cable) dvd out connect to tv... ? please note some dvd recorder will not record HBO (you can record on vhs tape)
no connect antenna to dvd in, dvd out goes to tv.....
hope this help...
May 20, 2010 | Quasar VHQ400 VHS VCR
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
Cant get a picture
1st-how do you have your "cox" cable box [you could have said it was a cox cable box!!] connected.Can you 'get a picture' through the TV without the VCR ? Do that! disconnect the VCR from the line and plug the TV directly to the "cox" box.Does it work? Are any of the cables connected from cox to VCR to TV damaged.? Let me know how you have the three(3) equipments connected.
Aug 07, 2008 | Toshiba W522 VHS VCR
Magnavox PIP, Insight Cable box, Sony DVD/VHS
1st conect cable, then 2. VHS , Then 3 dvd to tv.
Then you can record Cable wile watching a DVD
Nov 07, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
