Question about Canon MVX1i Mini DV Digital Camcorder
Mvx1i zoom does not operate at all
Has above , everything working but the above????/
Ok,
I had the same on mine and here is the explanation because fixing it is not easy to impossible.
I had it fixed on mine just to see it getting worse after that.
Reason: The Zoom Slider puts a resistor to some printed curcuit board just beneath it and if that gets oxidised due to age it stops working. Only the remote workes then.
Workaround (recommended): Use the remote.
Fixing it is nearlky impossible as the printed circuit board is on the other side of the camera from where you start opening it and you have to comletely dissasemble it. I did and tried fixing it by cleaning the circuit boad, but it somehow changed the restance value and then it was stuck in full zoom all the time. Then had to re-open again and sever the connection completely, thus having the camera stuck in full view at least. but because of this strange resistor concept of the design, having the connection severed does not disable the zoom but rather simulates constant zooming out. hence my remote is now not longer working.
Hence: keep it simple and use the remote and be happy.
Posted on Jul 05, 2010
My samsung pl20 camera was dropped and it say the zoom did not operate normally
Pull gently back and forth on the lens while in outward position. Do this several times until you hear a click. This will put the lens back in place and should go in and out afterwards with no problems.The lens was knocked out of alignment when dropped and do the above will put it back into alignment.
Jun 21, 2012 | Samsung Pl20 - 14.2 Megapixel, 5x Optical...
Can zoom in or out when in full page mode anymore, just started yesterday aug 10/11
there is a pretty obvious bug when using 'Marquee Zoom' (Alt+5) in the full screen mode (F11). When you press 'Ctrl' to toggle 'Zoom In' and 'Zoom Out' (changing the little magnifying glass cursor from + to - and back again), it sticks with 'Zoom Out' and refuses to toggle back to 'Zoom In'. And then the only way to recover 'Zoom In' is to exit full screen mode, whereupon 'Ctrl' regains its toggling power and everything is back to normal
Aug 11, 2011 | Computers & Internet
My computer is stuck in zoomed out mode and i want it zoomed in back to normal
I don't know what the operating system is but usually there is a zoom just above the task bar look for the+100% icon and click on that it may say +200% or +150% when you click on it the level should return to normal
Feb 05, 2011 | ASUS Eee 4G Notebook
I took that bettery out of my dell laptop and when i turned it back on everything was zoomed in, now i dont know how to fix it.
you did not provide what operating system you use, i assume this is windows? i am providing solution for windows xp
1. reboot the computer
2. if everything is still "zoom in"click righ mouse button anywhere on your desktop
3. select properties
4. tab on display
5. select better resolution than you have now
for future references, you need to give specific model (dell over the years produced over 220 models and if you count variants will be close to 500 different laptops! i know, i was one of they engineers once), operating system and then ask for help, telepathy do not work very well... hope this solved your problem :-)
Jul 29, 2010 | Computers & Internet
Sony dsc t300 e 61:10
   The detail of fault is given below,
Self-diagnosis Code   Symptom/State
E 61:10         Zoom operations fault
               (Cannot initialize zoom lens.)
Correction :
Retry turn the power on by the power switch. Check the zoom
reset sensor of lens block (pin 9 of CN402 on the SY-191
board), if zooming is performed when the zoom button is
operated. If it is OK, check the zoom motor drive IC (IC401 on
the SY-191 board).
According to the symptom the possible fault is described above, You have to contact any nearest SONY SERVICE CENTRE to rectify the problem.
 Thanks for using fixya.
May 30, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Zoom does not work
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Feb 17, 2009 | Canon PowerShot A520 Digital Camera
Logitech quick cam zoom
You can download from Logitech.
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Just pick your camera and then the operating system to download.
Mar 03, 2008 | Logitech Quickcam Zoom 5 Pack Webcam
Canon MVX1i Mini DV Digital Camcorder Logo
89 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
