Question about Konica Minolta magicolor 5550 Colour Laser Printer
Konica Minolta Magicolor 5550 Ink Replacement Error
I have Konica Minolta Magicolor 5550 which says it requires a new K (black ink) toner unit. When i replace it the screen still says it needs a new one even though the levels on that same screen show as full. I've tried rebooting. is their anything else that will work?
Tonerman
  • 62 Answers
SOURCE: Konica Minolta Magicolor 2300 DL
clean the machine , and change the toner.
Posted on Jun 02, 2007
SOURCE: Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Posted on Jan 06, 2008
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
  • 97 Answers
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
The fuser temperature is too high. There is probably some residue from the transparency left on the thermister or the thermister went faulty that causes a wrong reading. The only solution would be to have the printer serviced.
Posted on Aug 05, 2009
My yellow imaging unit is on back order, is there anyway to still use the printer until it gets here
Basically -no. If you could get a reset chip for it, you could probably carry on using the original drum for some time. For example http://www.tonerstop.com.au/konica-minolta-bizhub-c353-bundled-set-of-4-compatible-drum-chips
May 05, 2015 | Konica Minolta Konica Bizhub C353 Drum...
Konica Minolta Magicolor 2530DL streaks. maintenance
Lift drum out, look down behind toner and you will see a glass lens.
Clean it with a soft cloth or tissue. Works every time.
Aug 24, 2012 | Konica Minolta Magicolor 2530 DL Laser...
I have an error message on my magicolor 2550 ( Konica minolta) that says Replace K toner??
The K toner is the black toner. The K stands for "Key" as in primary toner.
Pages 80-107 list the toner part number that you will need to order as well as how to remove the old and install the new toner.
Mar 15, 2011 | Konica Minolta magicolor 2550 Laser...
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
THE KONICA MINOLTA MAGICOLOR 2530DL/ ALL FOUR COLORS OF INK ARE LEAKING ALL OVER THE INSIDE OF THE PRINTER, WHAT WOULD CAUSE THIS?
Most likely reason is the printer is either a display model, or previously been sold and returned. The toner cartridges are usually sealed and these seals need to be removed prior to use. I would recommend returning to the supplier and asking for a new one, with the toner cartridges sealed. Once toner has been spilt, it is very difficult to remove all traces. A standard vacuum cleaner may be suitable to remove the worst.
Mar 08, 2010 | Konica Minolta Magicolor 2530 DL Laser...
I just got new color toner and says is out.
In the engine menu, set it to continue on error. It will continue to print, but the error light will blink...
Mar 22, 2009 | Konica Minolta Magicolor 2530 DL Laser...
KONICA MINOLTA: CALL SERVICE 0017 P MOTOR 2
Our Magicolor 5550. It keeps coming up with the error message: CALL SERVICE 0017 P MOTOR 2 . Any idea as to waht it is
Dec 17, 2008 | Konica Minolta magicolor 5550 Laser...
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
Toner Cartage
Really Magicolor 2430DL is a very worst printer in this world.
within 2 months drum cartridge finish - no other printer like this type of option - like black, color & durm cartridge.
I will recommend - not to go for the thirdclass cartridge. go for only HP.
thanks
anil - dubai
Feb 20, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 5550 Colour Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
