Question about Dishwashers
The dishwasher only makes a humming noise when I try to turn it on. What's wrong?
  • 555 Answers
Sounds like the pump (not the drain pump) is not able to run. Perhaps something went into it and is jamming the pump. (bones, small pieces of glass, etc).
Posted on Sep 28, 2009
Why does it make a loud Humming noise?
Something is still in the main wash pump, you hear the motor trying to turn the impeller and it can not
Mar 27, 2016 | Dishwashers
Dishwasher wont wash! just makes a humming noise
Without knowing the brand and model it makes it a little hard to anser but I can tell you thats the typical sign that there is something wrong with in some machines, the pump/motor assemble, in others the recirulating pump, but a technician should be called.
Apr 29, 2012 | Dishwashers
Dishwasher fills with hot water then does nothing
Do you get any humming noise when you turn it ON?
How long its been you used the dishwasher last time...?
If you are getting an humming noise then Sounds like the water circulator pump is stuck. The motor tries to turn it (humming noise), but cannot. So a breaker trips (self reset). Not claiming this is actually the problem, but this is what the motor turns.
Aug 30, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Very loud humming or whirling noise
it could be the motor starting to seize or the windings in the motor could be going bad either way it should be serviced
Jan 13, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Old ge dishwasher
Hi loda83,
I'm Harvey the Master Plumber.
Your problem is: there isnt any water going to your dishwasher and its just making a humming noise when you turn it on
The most likely culprit is the solenoid valve. It is a simple on/off valve under the d/w on the left. Depending on make and model I might remove the d/w from the cabinet to facilitate installation. Don't forget to turn off the water first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Dishwashers
Dishwasher stopped washing just making a humming noise
humming noise is the wash pump energised but not turning.
this can be:
wash pump seized up
foreign object stuck in the pump impellor.
pump capacitor faulty - a common fault. if pump turns freely by hand but not when energised, then the fault is probably the pump capacitor - cheap part
Aug 22, 2008 | Whirlpool Dishwashers
Motor spinning? Arms not turning.....
When the dishwasher fills can you hear the wash motor does it make a humming noise if so it may be blocked if it makes a rattling noise the impellor may have broken off. I dont recommend sticking a screw driver in it from behind you may damage the windings.
Feb 29, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
Dishwashers Logo
85 people viewed this question
Top Dishwashers Experts
