Question about Compaq Evo N1020V Notebook
MY LAPTOP COMPAQ N1020 V HAS A BOOTING PROBLEM
FOR SOME TIME NOW I HAVE BEEN HAVING PROBLEMS WITH MY LAPTOP. ( COMPAQ EVO N1020V) IT WILL SOME TIMES BOOT BUT FOR A SHORT TIME THE COMPUTER WILL FREEZE. SOME TIMES YOU CANNOT SEE ANYTHING ON THE SREEN EVENTHOUGH YOU HEAR THE FAN WORKING ALL RIGHT.
  • 1 more comment
  • Anonymous Jan 09, 2008
    Yes, I have the same problem with my Notebook. I try other memory chips and check the harddisk with a USB High Speed Cable Interface. But this didn't solved the problem.
  • Anonymous May 28, 2008
    Laptop won't Boot
  • benjamin c May 12, 2009
    When we try to boot it up, it turns it's light on but the screen doesn't turn on. I pull it apart, take the prosseser out and put back in. It works fine but when I go to turn it on again, it won't work
    Novelist:
  • 188 Answers
I'm not sure what good getting into safe mode is going to do?
More than likely this is a hardware problem - If you have already tried different RAM the next thing would be CPU. You may be able to just reseat the CPU in it's socket to help things out.
On the N1020v to access the CPU, you just have to remove 2 screws underneath the power button strip and then the keyboard just pops up. Remove the heatsink and the CPU is right there. If you want to replace it use the part number on the CPU itself (something like SL245)
To forewarn you though - i have worked on these laptops many times and more often the problem is a failing motherboard than a bad CPU or RAM. However it is worth a shot at fixing it if it just needs a CPU.
Don
Posted on Jan 16, 2008
Hi shaggy242 when you say under the power strip how izacly do you get to that also the laptop i had loads of bits got removed out of it ive put new stuff in but the screen dosent work and when i plug it into the monitor nothing happens can you or anyone help me many thanks
Posted on Jan 28, 2008
  • laptop man Jan 28, 2008
    hi shaggy242 when you say under the power strip how izacly do you get to that also the laptop i had loads of bits got removed out of it ive put new stuff in but the screen dosent work and when i plug it into the monitor nothing happens can you or anyone help me many thanks
  • 383 Answers
Getting into Windows Safe Mode
The above solution should get ya back up and going normal, follow instructions. Good Luck, Please dont for get to Vote.Thank You.
Posted on Dec 19, 2007
How to connect external monitor compaq evo n1020v
Plug the cable VGA in to the compac and the laptop. than go to graphic properties and activate your extended desktop. You can also use the monitor as a second one, or clone
Jan 29, 2013 | Compaq Evo N1020V PC Notebook
Power hub usb problem . compaq laptop evo n1020v. do i need to update the bios?
Please uninstall all the USB Drivers from the Device Manager and then restart the Computer. The USB Drivers are Operating System generic Drivers. The Computer will reinstall the Drivers for USB automatically
Jun 30, 2010 | Compaq Evo N1020V Notebook
Compaq Evo N1020v operating system not found. I dont have recovery disk and also it dosnt seem to pick up xp when I insert into CD Drive. What could be the exact settings to boot from CD Drive?
Make sure that your CD is Bootable. Now you will need to do settings in BIOS to boot from CD..
1. Power ON the computer and Press "Delete Key" or F1 or F2 or F10 Key to enter in BIOS.
2. Goto Boot Menu Options
3. Select First Boot Device to CD / DVD
4. Second Second Boot Device to HDD
Now Save Settings and exit . it will reboot computer . If your CD is bootable then it will ask to boot from cd message.
Option 2 :
You can try by pressing F12 or F11 key simultaneouslty after power ON computer. It will display Boot Menu so from there you can select "CD/ DVD Drive " and press enter then it will boot from computer.
It will glad to help you further if your problem doesnot get resolved.
Mar 28, 2010 | Compaq Evo N1020V PC Notebook
Compaq EVO N1020V Not reporting RAM correctly
This sounds as thought he RAM is faulty.
You need to have installed 2 x 512 MB DDR 266 SoDIMMs and not 1 x SoDIMM.
If you have placed 1 x 1Gb SoDIMM in ther EVO this would account for you only seeing 480Mb of RAM.
Sep 24, 2009 | Computers & Internet
Compaq presario 900 512 ram to 1 gb?
go here http://www.corsair.com/
and do a memory scan
Jul 07, 2009 | Compaq (291647-001) for Presario 900 /...
Compaq evo n1020v not able to boot, no displal.
You have a sick laptop, could be simply a faulty power adapter to a faulty motherboard. The Evo is old and probably not worth fixing, better to put your money towards a new laptop.
There is a way to retrieve data from your hard drive provided it is not faulty.
Remove the hard drive from the laptop and connect it to an USB hard drive adapter. Insert the adapter into a working computer's USB port and the computer will see this as an external hard drive. You can then open the folders and view your files. Copy the various folders and files you require to a USB memory stick and/or burn these to a CD etc.
It pays to backup your data regurarly because if the hard disk fails and this can happen unexpectedly, you will lose your data.
If the hard drive is faulty, there are companies that can retrieve data from faulty hard drivers, but it will cost you an arm and a leg for their services.
Jul 06, 2009 | Compaq Computers & Internet
Computers & Internet Logo
361 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
