Question about Hitachi Cine Master PJ-TX200 Multimedia Projector
Hello, I have a faulty Hitachi PJTX-200 projector. It is about 2 years old. The HDMI input does not work (it has done in the past). It simply says no input detected. I have tried a couple of different sources with the same outcome. It works fine using the Component inputs. Is there anything obvious I can try?reset, configuration etc?? Can you advise where I can send/take it to get repaired? Many Thanks, Andy Chick
I have exactly same problem with my TX-300. Suddenly HDMI not working. Tried several cables...Component working. Have you resolved yours?
Brgds
Stale
Posted on Sep 21, 2014
Have you tried replacing the cable ?
Posted on Dec 27, 2009
How to work the hdmi
how do you set up the HDMI input on a hitachi tv model #51F59A ...
https://answers.yahoo.com/question/index?qid...
Jan 8, 2010 - i tried to hook up an HDMI devise but i cant set it on input HDMI it ... My TV has HDMI, Component and AV inputs, which one should i use for my ...
HDMI not working - Hitachi 50VS69A - AVS Forum ' Home Theater ...
www.avsforum.com/.../948284-hdmi-not-working-hitachi-50vs69a.html
Dec 1, 2007 - 7 posts - ‎2 authors
I have a Hitachi 50VS69A 50 RP LCD HDTV connected to a Dish Network receiver that the HDMI input is not working on. I have been using the ... Hitachi P50H401 - all HDMI ports are dead - HELP!
Oct 2, 2008
Hitachi 51/57/65F59A CRT RPTV Tweaks Thread
Jan 19, 2007
More results from www.avsforum.com
Dec 27, 2015 | Hitachi CLE-960 Remote Control HL02121
There are some white dots on the projection
The DLP chip of the projector has gone bad, which require to be replaced.
Aug 17, 2015 | LG HS200 SVGA 200 lumens LED Projector;...
PJ-TX300 suddenly not detecting HDMI input
I think that its a port issue, if all the other ports are working but hdmi is not then one of the pin on the circuit board may have come loose. I have the same issue. Could try to solder it back on or use a glue gun. let me know if this helps?
Sep 21, 2014 | Hitachi PJ-TX300 LCD Projector
Getting no audio from speakers on a Vizio E421VA LCD HDTV, any ideas?
Do headphones work?
my guess is either the headphone socket or associated wiring/soldering is faulty or there is a faulty connector within (connector associated with the audio)
Jun 19, 2014 | Vizio E421VA 42" LCD HDTV
I just installed a sharp dt-200. I used a converter in the DVI-D port to HDMI, which I have done in another house with the same device without issue. When I turn it on, the picture turns on and off...
Is the input set to a resolution that the projector supports over HDMI? Some of them can be quite limited and only support the normal HDTV subset, which doesn't necessarily include many common PC resolutions. Ditto refresh rate.
Only thing I can really think of right now, other than a duff cable or converter.
Jan 31, 2014 | Sharp DT-200 Multimedia Projector
Samsung hitachi sync out of range
take the blue ray disk out, turn your blue ray on and connect to a tv monitor, go to menu, and for hdmi option select 720p then reconnect your hdmi cable to the projector, it should come on, go back to menu, and match the input of the projector to the right type hdmi output from your blu-ray.
there is nothing wrong with your projector.
tony
Feb 20, 2013 | Hitachi Office Equipment & Supplies
Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Feb 17, 2009 | Hitachi 50V720 Television
We have a Toshiba TP50H95/TP55H95 Color Stream Projection TV that is 10 years old and we recently switched cable companies. Since then the picture is not filling the screen completely on bottom or on top...
A to expensive to fix part is going on the projector. Suggest you get a new one. I've owned 3 projectors over the years. The best one is a Viewsonic 7820hd. 3000 to 3200 lums brightness, short throw lens (104" screen at 12 feet from the projector) 1 HDMI input 1 RCA input 1RGB input and 2 computer inputs. Price varies- but I got mine at Tiger Direct 3 yrs ago for $488 bucks- the Viewsonic 7822 (2 HDMI inputs) is on the Viewsonic website on clearance or refurbushed for around that price. AND- They do a full 1080 HD and also 3D.
Jun 02, 2017 | Televison & Video
No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Dec 04, 2007 | Hitachi PJTX100 Multimedia Projector
Hitachi Cine Master PJ-TX200 Multimedia Projector Logo
239 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
