Question about Canon PIXMA iP1600 Printer
Changed ink, now it doesnt recognise the new ink/ how do I by pass this?
Printer reports out of Light Magenta ink even after new cartridge installed.
discovered recently that printer cartridges have a use by date on them, and that if you use it the printer will not recognise it, only answer is to insert a new one, or ignore the printer ( l have a by-pass function on mine so still use it until l am ready to replace the offending cartridge
Jan 30, 2013 | Epson Stylus Pro 9900 - 44" large-format -...
Epson 2100 will not recognise new cartridges
Change ink tank using "How to..." at Epson status monitor. Check contactor that connected to ink tank chip at carriage. Other possibility is CSIC board (behind the contactor)
Jan 21, 2013 | Epson Stylus Photo 2100 InkJet Printer
Bought brand new ink but it keeps saying it doesnt recognise the ink i have put in
Take the cartridges out. Clean the contacts on the cartridges, (brass color,) with a lint-free cloth. With a almost dry damp cloth, wipe the exit areas where the ink comes out, just a couple times. Unplug the machine. Plug it back in. Open the barn door, and install ink cartridges. Allow the ink cartridges to re-align. Printer should work fine.
Nov 16, 2010 | Epson Stylus Photo R320 InkJet Printer
Mfc 440cn printer says 'ink empty' to new full ink cartridge
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. But if the circuitry on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink catridge in it, that was working fine, until...it suddenly did not recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and prbably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also because they design the machine to be totally useless unless all the ink ccartridges are full. Shame on you Brother, and kiss my *** for the $160 pile of junk I bought off you that was only on its second batch of cartridges (ie very little use)
Jan 19, 2010 | Brother Office Equipment & Supplies
Hi, I have an epson sx205 and its been working perfectly fine until last week when it said that the black ink could not be recognised. When i took the ink cartridge out, it was empty so i simply replaced...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 23, 2009 | Office Equipment & Supplies
Brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Jun 03, 2009 | Brother DCP-330C All-In-One InkJet Printer
My black ink will not print. If I change the colour, it prints find. It is a new cartridge.
First you need to ensure that this is not a driver problem, by reinstalling drivers and testing the printer on a different computer.
Also ensure that ink cartridges are OK, try replacement inks.
If the problem is not a software problem, and the printer is recognised by computer, and the printout is coming as a blank or faded page, then you usually have a faulty or clogged printhead.
Try first performing print head cleaning procedure from printer tools, that may not fix the problem, but do the cleaning a couple of times, just in case.
If the print head is clogged, that can be fixed soaking the print head in isopropyl alcohol overnight.
If still no luck, then the printhead must be replaced, here is the part: Canon MULTI-PASS F-80 Print Head $61.00
Apr 26, 2009 | Canon MultiPASS F80 All-In-One InkJet...
HP Business Inkjet 2800 Problem
there is a sensor which recognises the amount of ink u have in ur cart. if that sensor doesnt work, then printer will not recognise the ink in the cart. Try cleaning the copper contacts on the printer cart slot. if no go. look for service..
Sep 25, 2008 | HP Business InkJet 2800 Printer
Ink carts not recognised
OK, i know this one ;-)
1 take out the cartridge thats not recognised ( 1 or all dont matter)
2 do a ink change with no ink in
3 put ink cartridge(s) back in.... wiggle the cartridge(s) to seat the "chip" right
4 do a ink change again, if not just follow the steps again.
I had to do this 5 times the other day before it picked it up.
It does work
Jan 31, 2008 | Epson Stylus Photo R300 InkJet Printer
Canon PIXMA iP1600 Printer Logo
22 people viewed this question
old marine
old marine
