Question about Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer
Unable To Print Error F4.\ Brother printer
Unable To Print Error F4. Brother printer MFC-240c
How can I clear it.
pineworks
  • 4041 Answers
SOURCE: MFC-240C PRINTER DISPLAYS "INIT UNABLE 4F" WHEN TURN ON
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
eliza_syafik
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
clean unable 46,see troubleshooting and routine maintenance chapter in user guide.Plase help me to splve this problem.
Posted on Aug 12, 2009
komguy
  • 2306 Answers
SOURCE: How do I clear
51 error says that the purge assembly is stuck and not cycling properly. If you can power up and get the printhead to the center and unplug again, look with a flashlight in the far right corner where the printhead parks for any paper scraps or things that don't belong and remove them it might work again. Otherwise a shop repair to possibly replace the cleaning assembly.
Posted on Oct 02, 2009
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
Posted on Feb 18, 2010
pineworks
  • 4041 Answers
SOURCE: brother mfc 240c error says print unable 51
Hi Ok try this it may work.
Hapens a lot
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Shows print unable 4F
The LCD displays an error code with problem with Printhead. To fix Brother Printer Error Code 4f go through eh 2-3minutes read of blog either or connect o right experts for assistance. The causes to this error is connection failure of the carriage-head flat cable or head flat, Print head defective, Power supply PCB defective, Main PCB defective. Looks of the causes and move ahead with the issues. Brother to help you settle on your printer obtaining choice, read the Brother Printer Error Code 4f surveys and evaluations. Impart following Model Brother Printer such as:
    ·Brother multifunction printers
    ·Shading laser printers
    ·inkjet Printers When you are searching a Brother Printer answer for a home used or home office, little or medium business, or substantial business or workgroup, the impartial Brother Printer tech experts direct you towards the right printer solution. Connect to Brother Printer Support Number for proper and one to one assistance with experts.
Brother Printer Technical Support Blog News 1 800 213 8289
Dec 28, 2015 | Office Equipment & Supplies
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
Troubleshooting : unable 4f cant print
Error 4f mean the head drive voltage has dropped from the high to low level in an abnormally short period.This mean your printer need new print head.This will cost you just as a new printer, then think about new printer.
Nov 04, 2009 | Brother Multi-Function Center MFC-240C...
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Print unable see trouble shooting and routine maintenance
sending fax is working alri.ght, only when I try to recieve fax it gives an error 30 on the display. At the same time it unable to clean. Please help me with this.
Jan 17, 2009 | Brother Multi-Function Center MFC-240C...
Brother mfc-240c printer error message unit unable 43
http://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=fax2440c_us_eu&faqid=faq00000168_003
Jan 06, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-5860CN print unable 51 error message
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
891 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
