Question about DeLonghi Dehumidifiers
I want to change my deLonghi Dehumidifier from emptying into the container to continuous flow into the sink. I was given this from a friend, not new and dont have a manuel or the hose to change it over. Any suggestions?
    President:
  • 1,653 Answers
You may have a older model that has a collector tank with a protruding tube on it. If so just cut the end off the tube and slide on a piece of clear 9.5mm internal diameter PVC / Rubber tubing suitable for a fish tank air / water pump and secure it with a nylon tie wrap.
Continuous external draining for newer models with clear collection tanks.
If the appliance is to be operated for long periods of time but you are unable to empty the tank, you are recommended to use the continuous drain facility.
• Drill the inside of the drain spout using a small drill bit. This is located behind the rear grlle in the lower centre of the opening.
• Fasten the rubber hose to the spout. For models without drain hoses supplied, we suggest you purchase a rubber hose around 2m long, with an internal diameter of 9.5 mm.
• Make sure that the hose is not higher than the spout, otherwise water will remain in the tank; also check that the hose is not twisted. N.B: Keep the rubber bung. You will need it to plug the hose or close the spout if you revert to draining into the tank
Posted on Sep 28, 2009
Testimonial: "Very helpfyl I think. I will se when I get home where the drilling needs to occur."
Our DeLonghi condensation removal system no longer removes moisture; it appears to run fine; the lights indicate all systems are on. I have cleaned the filter; cleaned the tube; disconnected the tube; set...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 28, 2011 | DeLonghi DH100P Dehumidifier
Just purchases the DD50PC. Set the pump to continuous, hooked the hose to the slop sink in basement approx 8 feet, pump running fine but when looked at it the next day the pump had shut off and the tank...
The reason this happened may be two fold. Either the hose is clogged or the length of hose is to long and then has to go up hill into the slop sink. The owner's Manual says the pump is rated for an 8 foot lift. However, what I have discovered is that rating, does not take friction loss in to account.
Try moving the unit closer to the sink and shorten the hose about a foot or two. Actually, a floor drain would be perfect, if you have one in your basement.
Hope this helped you ad thanks for choosing FixYa.
Aug 07, 2011 | DeLonghi DD50P Dehumidifier
I was just given a DD50PC as a gift from a friend who did not have the accompanying instruction booklet. He told me to turn the unit on and let it work. I do not know what temp to set it at. It has to...
On a dehumidifer, you set the relative humidity, not temperature. Normally the humidity should be set within 40 to 60 percent humidity.
Click on this link for a copy of the manual for your machine. www.sylvane.com/images/.../delonghi-dd50p-dehumidifier-user-manual.pdf
Hope this helps you.
Jul 01, 2011 | DeLonghi DD50P Dehumidifier
Dehumidifier isn't not removing humidity. Fan and lights are working, but the water container remains empty. It is not pulling water from air. I think that the heating element may not be working.
heatman101
May 25, 2011 | DeLonghi DE500P Dehumidifier
Bucket is empty but it is beeping
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Apr 08, 2011 | DeLonghi DE400P Dehumidifier Dehumidifier
New Delonghi Dehumidifier,5 gal:When units beeps that bucket is full,what are exact steps to do 1st:empty bucket, then press what button to restart?or does it restart on its own?
It should resart on its own after putting the empty bucket back in. The beep is to let you know that the bucket full and it shuts off the humidifier until the bucket is emptied and put back into the proper position.
Jun 07, 2010 | DeLonghi Dehumidifiers
I have a Maytag M7DH65B2A. I hooked up a hose to
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 20, 2009 | Maytag M7DH65B2A Dehumidifier
DeLonghi 50 Pint dehumidifier DE 500P won't turn back on
If it is not responding when you try to activate the shutoff button and are still not recieving an acknowledgement that the bucket is full you may hav a defective shutoff button. Try contacting the Manufacturer and see if you can purchase just the button. This i a common part and the price is usually reasonable. If you feel very technical inclined you can remove the button and touch the 2 wires together simulating a closed contact. The dehumidifier should now acknowledge the bucket is full. If you recieve the notification then the button is bad. If you found this solution helpful please rate it.
Thanks - Tech101
Sep 04, 2007 | Dehumidifiers
Dehumidifiers Logo
299 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
