Question about Kenmore Refrigerators
My Kenmore coldspot refrigerator is not producing ice. The water works fine, but no ice.
  • Kenmore Master
  • 2,605 Answers
I'd start by making sure the ice maker is not simply "shut off". no offense, it is a common occurrence. the unit can be shut off several ways depending on the model you have. some ice makers have a switch right on the ice maker module/head. some have a switch at the side wall of the freezer, if it has an ice bucket on the door, and most if not all ice makers have a shut off arm to automatically shut it down when it's harvested a full bucket of ice, which can accidentally be pushed up into the off position by simply reaching in to grab ice or something other. if all that has been ruled out, ok.
next, start by pulling the unit away from the wall, or whatever the case may be in your environment, as long as you have access to the rear of the unit. (be careful of the water supply line) I should add just because you are getting water from the dispenser on the door does not necessarily mean anything about the ice maker.
**FIRST; before going any further, unplug the unit from the wall**.
now that the unit has no power. shut off the water to the unit. examine the water lines traveling along the back of the fridge so you're familiar with the routing of the lines.(draw a picture/take a photo if you think it's helpful) if this is a bottom mount, you'll see the water line for the ice maker at the lower right hand corner, if it's a top mount, it will be located towards the top right corner, (provided you're facing the back). identify where the line enters what they call the "injector" or "supply tube". you'll notice the line being held in place by a small clamp of some kind. remove this clamp. once the clamp is removed, gently pull the plastic line out of the tube. if you've got the line out of the tube, tape it to the back of the fridge out of you're way, careful not to kink it or lay it on the floor, it could be damaged or water may leak onto the floor. now you have to pull that injector tube out of the back wall. it may be pressed in there (should be) fairly snug, so you'll have to apply steady force while twisting it back and forth, it should pull out and is likely several inches long. once you have that out, is it iced up ? you'll likely have to replace the inlet valve for the ice water supply. some units have a water/ice valve all together with 2 valves on it, some have separate valves for water and ice. you'll need to determine which one by looking or even better, cross reference with the model and serial numbers at an on-line parts supplier or local parts depot.
hope that helps,
good luck
Posted on Sep 28, 2009
I have a Kenmore Coldspot Side by side refrigerator model 58787892. The ice maker is not making ice. The mechanics of the maker work but it does not fill up with water. The filter is changed regularly...
check to see if the ice tube going into the ice maker is frozen up. you may have to thaw it out to get water to reach the ice maker again. lmk if that's not it
Aug 05, 2013 | Refrigerators
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
2002 Kenmore coldspot 51262103 model number Just hooked it up to water and it runs slow and the ice maker is blinking red.
Not sure if I resolved the issue, but after defrosting my icemaker, with a blow dryer for a second time. It seems to be working fine again.
Is it possible maybe there was some ice build up and every time it added more water for the ice cubes the water level was to high making it impossible for the auger to push the ice thru?
Jun 15, 2009 | Kenmore Refrigerators
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
Mar 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
94 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
