Question about Sharp AL 1631 Copier
Our copier is not copying anything. If you put it
Our copier is not copying anything. If you put it on the glass the part inside the glass does not move and if I put it up top to go through it makes a high pitched noise and comes out blank.
    President:
  • Sharp Master
  • 1,447 Answers
Your copier scanner is lock. if you have a user guide then follow the instruction.How can unlock?and where. I know where is ,it is copier delivery side under scanner or copy board please moving unlock position
Posted on Sep 28, 2009
How to use the Copier only, instructions please?
copy machines work by running a light along under the glass
anything on the paper is reflected and the image is captured for reproduction
so place the printed surface face down on the glass
Aug 30, 2015 | Canon PIXMA Office Equipment & Supplies
Black line occurs when I auto feed on copying. NOthing else. Thank YOu.
Try lifting up the document feeder and look for a piece of glass just to the left of the big piece of glass you put your originals on. Check the small glass for any spots of dust or anything on it and try cleaning that glass with windex.
May 25, 2011 | Brother MFC 7840W Printer
I have a sharp ar-bc 260 have perfect black lines on copies only copy mode print mode is fine
Clean all your glass including the thin strip on the left side that handles scanning for the doc feeder. Run copies both off the glass and the doc feeder. If the line is still there then take off the glass, dust the inside scan cavity and dust your 3 mirrors with a new, lint free rag. Make sure your glass is completely clean before you put it back on.
Jan 17, 2011 | Sharp AR-BC320 All-In-One Led Printer
Black streaks on copy
This can be anything from something on the glass to charge corona dirty, laser dirty, drum or blade or fuser rollers need to be replaced. For the average person, the best you can do yourself is to make sure glass is clean. Question..... do you get this line if you're printing also? If yes then that would eliminate the glass and has to be something inside. If no, then look very carefully at the glass and long skinny glass on top, if it has that, for white out or something on the glass. Sometimes you won't even see spot unless you look at just the right angle. Good luck. Please rate this if it helps.
Jul 03, 2009 | Sharp SF 2020 Copier
New toner but still have dark streaks
IF YOU ARE ONLY GETTING THE LINES WHEN YOU PUT THE DOCUMENTS INTO THE TOP FEEDER AND NOT FROM PRINTNG TO COPIER OR IF YOU PUT A COPY ON THE GLASS UNDER THE DOC FEEDER AND NO LINES APEAR CHECK THE SMALL GLASS WINDOW UNDER THE DOC FEEDER THERE MAY BE SOME TIPEX OR INK RUBBED OFF AND LEFT ON THE GLASS THERE.. THISD MIGHT BE CAUSING THE STREAKS YOU CAN CHECK THIS BY PUTTING THE PAGE IN THE DOC FEEDER AND DOING A COPY AND THEN PUT IT ON THE GLASS PLATE UNDER THE LID AND DO A COPY OR IF HOOKED UP TO COMPUTER DO A PRINT JOB.. IN NO STEAK APPEARS YOU CAN BE SURE ITS ON THE THIN SCANNER GLASS.. GOOD LUCK ...a
Jun 24, 2009 | Xerox XC356 Copier
Hp printer won't copy
the ink inside of the cartridges is gelled.
Feb 06, 2009 | HP Office Equipment & Supplies
Sharp AR-207 copier puts .5 inch black line across entire bottom of copy
does the line only show up when making copies from the adf or both when you put it on the glass. if only when thru the adf the **** glass is dirty. that is the glass that is only about an inch wide. be carefull of the two pieces of tape that are on both the front and back of that glass they fall off easly.
Oct 18, 2008 | Sharp AR-207 Copier
Platen is open message, What is the platen?
Platen is usually referred to as the Copy glass ( Platen Glass) this is where you lift the top to put it onto the glass to make a copy.
Never heard of this message , was it serviced? usually the techs open it to clean the Optics (mirrors) inside.There should be a metal plate with 2-4 screws that hold it.
Aug 28, 2008 | Canon imageCLASS D761 Copier
ADF
There is something on the small slit glass. There should be 2 pieces of glass on the copier. One where you place your original, and the other is a small slit glass about a 1/2" width by 9" long. Check the small glass to see if there is anything like a spot of black INK or a dot of white out on there. There is something on the small piece of glass that is causing your line problem.
Hope this helps.
Good luck.
Mac
Feb 08, 2008 | HP LaserJet 3055 All-In-One Printer
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
Sharp AL 1631 Copier Logo
61 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
