Question about Mitsubishi WS-55807 TV
Mitsubishi CS-40FX1 won't power back on
The tv was working fine but I could not turn it off with the remote control or the panel on the front. I tried programming several other remotes and none would turn it off so I unplugged it and took it to my local repair shop. The guy there said he thought that the microprocessor was bad and that he could not find the replacement part for it. I worry because I had thought it something simple because the TV was working perfectly and now he tells me I just have to toss it away. This does give me the ammunition I need for my wife to go and get a Plasma but I just hate to scrap such a great TV. 40" tube is beautiful picture. Any insight or help would be greatly appreciated.
Thanks,
John
I have a similar problem. I have a CS40fx1, when I turn on the set there is no picture, just sound, then the tv just turns off. I can turn it back on but its goes off after 10 seconds or less. Any help on what my problem is on this set?
Charles
Posted on Aug 20, 2008
Verticar the sincronism
Posted on Jan 11, 2008
    Genius:
  • 1,153 Answers
Yes Sir, you need to read threads here or go to ctechnicians.com and it will tell you how to get set to work.
Posted on Dec 18, 2007
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Mitsubishi CS-31205 TV Never had a remote for this great TV, but, accidentally pushed a button on my Comcast Cable remote and the TV is now in "Mute" mode. Not the Comcast box 'Mute' . Have...
You are supposed to be able to switch the Comcast Remote to TV mode and switch Mute on that remote to change back to standard volume. If that doesn't work try volume up on the TV. Otherwise if neither of those work then check Remotes.com for a replacement TV Remote.
Mar 09, 2011 | Televison & Video
Mitsubishi cs-26201 with "speaker off" - how to turn back on?
After a pulled plug got me Speaker off I was frustrated for weeks and found no solution online until I looked at a site offering original remotes and realizes I was using a VCR's remote for the TV. The Manual was long ago destroyed and is not available online that I can find, but I dug around for the oriignal remote and clicking the Audio button repeatedly brought up the Speaker: Off option and then it was just a press of Adjust to turn it back to On - problem solved.
I don't know if there is a way to do it without the remote, but the only controls on the TV are those on the front and in addition to steps people online suggested I think I must have tried every combination possible of pressing those in sequence or together as well as everything I could think of on the other Mitsubishi remote and the Universal remote I had been using.
Sep 04, 2010 | Mitsubishi CS-26201 TV
Television is dead. won't turn on picture or
There is a fuse in tvs I've had to change one myself
Oct 16, 2009 | Mitsubishi CS-26201 TV
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Dec 28, 2006 | Mitsubishi CS-35505 35" TV
Mitsubishi WS-55807 TV Logo
300 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
