Question about Philips 42PFL6704D 42 in. LCD TV
Problems with volume turns up and down on its own
  • Philips Master
  • 1,213 Answers
You may have bad connection to the signal board. The connection is tight due to the shrink tubing making the strain. Have a tech peel it back and that should fix this problem!
Posted on Apr 14, 2010
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
How do I turn down the volume on DVD portable Sylvania without remote
To turn the volume hold down the play/pause button
To turn the volume down hold down the stop button
Aug 31, 2014 | Sylvania SDVD1030-RED 10-Inch Portable DVD...
Techwood tv volume going back down
I've got this problem these fixing only work for a sort time! Volume just turns itself down?! Anyone no the real fix?
Jul 03, 2012 | Televison & Video
My laptop has developed a high piched squeal if the volume wheel is turned up too high
If you have a built-in microphone, turn the mic volume down (right click the speaker icon on the bottom right of the taskbar, click "open volume control" then turn down the mic volume or mute it.
hope this helps.
May 03, 2011 | Toshiba Satellite L505-ES5042 Notebook
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Apr 11, 2009 | iLO 3200 32 in. LCD Television
I cant turn volume up on my sandisk clip
My problem seems to be a damaged volume button. Once I tour the volume down (the down button is fine) I could not increase back de volume.
This is a palliative sollution. You need to reset you Sansa clip to get the volume set to the "middle" of the range. To steps are:
1) clique in the "home" button.
2) navigate to "settings"
3) select the "Reset All" option and confirm it.
Apr 02, 2009 | SanDisk Sansa Clip MP3 Player
Volume control keeps going up and down when I turn down the volum
Volume Switch (Encoder) needs to be replaced professionally. Desolder the old one properly, and insert/solder the new part. Problem solved. Order part from here:
http://parts.pioneerelectronics.com/model.asp?modelNum=VSXD498
Part number asx7004
Dec 04, 2008 | Pioneer VSX-D498 Receiver
Verizon phone mute button
Talk about silly. This is the 3rd time typing the solution. (The Terms of Use link wiped it out too.) I had same problem by accidentally setting mute from bluetooth headset. If you have same situation, just turn volume up or down on headset. (Turning volume up or down on cellphone did not help me.) Good Luck,
BeenThere
Mar 26, 2008 | Cell Phones
Philips 42PFL6704D 42 in. LCD TV Logo
184 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
