Motor humswhen turned on. Removed pump and rotated motor shaft, put back together and worked but made a loud clicking noise. turned off and tried to turn back on again. Motor just hums as if something is keeping it from turning. Checked and replaced coupling also.
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Providing motor runs free, nothing is sticking it...Fit replacement motor
Posted on Sep 28, 2009
  • 11,896 Answers
I was going to mention the coupling, since that is new, then I would suggest motor brushes or new motor. As long as you are getting sufficient power to the motor. about minimum of 12-13.5 volts
Why does it make a loud Humming noise?
Something is still in the main wash pump, you hear the motor trying to turn the impeller and it can not
Mar 27, 2016 | Dishwashers
Whirlpool Side by Side. Husband replaced fan motor inside freezer. Ever since it's been replaced, it runs frequently and hums loudly. Any suggestions. He took the interior back out and it doesn't hum.
The fan blade touching the interior back cover????
May be the fan motor shaft is too long or may be he did not push the fan blade well inside into shaft so it is to much out. Thus touching the wall cover plate..????
Sep 24, 2014 | Whirlpool Refrigerators
Gear alignment on outboard motor
When the gear box ix in forward, it should make a ratcheting noise when rotated forward and should not turn at all when turning in reverse (or be resistant as your back spinning the water pump -don't do that) Once in gear (forward ) you should be able to mate the shift to the motor. I have removed the prop and nut and used a remote start to spin every thing together, but requires a lot of safety precautions.
If you are working on an older mercury, that shift rod can work both ways with disastrous results if you over spin the shifter to the back side of the detent.
Sep 17, 2012 | Boating
My Reddy heater torpedo multi fuel heater won't start this year. It makes a loud humming noise for a minute or so and then nothing. If I try starting it a few times in a row it will make the noise...
Remove the top cover and rotate the fan by hand. If should turn pretty easily. If not may you can put some oil where the shaft passes through the ends otherwise you will need a new motor. If the fan turns easily then the capacitor is probably shot. I don't know if you can get the capacitor seperate from the motor or not. There is a small low pressure compressor attached to the back of the motor. Your problem may also lie in there. The covers come off easily so you can check it out.
Dec 29, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Pump hums when switched on but does not work more than 20 seconds
hi i had the same problem with my booster pump motor it hum but did not turn. to make a long story short see if there is a metal cap on the back of your motor if there is pry it off and you should get to see the shaft turn the shaft with a screwdriver if it has a notch in it or if it don't turn the shaft anyway you can and make sure it turns easy. my shaft was tight as hell but i got it to turn and it started right up again and i had no problem. the hum means it is stuck and it shuts off because the breaker is tripping and after a few seconds it will click back on again, hope this helps
Jul 06, 2009 | Emerson Pool & Spa
Fills the hums loudly
Hello , Have you looked inside the pump where the hose comes from the tub , there could be an item clogging it , also try turning the pump where the shaft goes by hand , it should turn freely.
You can also try turning the gear case with the motor off where the coupler is attached , 1 direction will agitate and the other direction spins , you should be able to turn the gear case both ways and it will not turn easy.
if all of these check out the motor could be bad but it is highly unlikely.
let me know how it works and if you have any other questions.
Phil
Jan 08, 2009 | Kenmore 15864/15862 Top Load Washer
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
I have an LG TDC70080E condenser tumble dryer. It has worked perfectly for 2.5 years and now is playing up (suprising, considering it is just out of warranty!) There are two issues: 1. The drum is not...
My pump started making a loud noise and stopped pumping, I removed the pump and found that the impeller had moved down the shaft, so I put some locktite on shaft replaced impeller and its fine now
Oct 28, 2008 | Dryers
Kitchen aid dry motor noise
Try taking it apart again and try to turn the motor by hand. It should spin freely. If it does you've probably got a bad motor. If it is stiff or doesn't turn at all, then you might have missed something putting it back together. I wouldn't think you can overtighten the blower, it is probably something else, and with it apart it should be easy to see.
Jul 21, 2008 | KitchenAid Dryers
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
