Question about Lexmark X6180 Printer
DOES THEESE PRINTERS HAVE A FUSE IN THEM THAT CAN BE REPLACED,IT WAS WORKING FINE,AND NOW I HAVE NO POWER TO IT?
    Problem Solver:
  • 10 Answers
It's not something manufacturers like you doing so they usually don't sell poarts like that, and if they did, to presuade you not to do it yourself, if would not be cost effective (compared at buying a new printer)
Posted on Feb 08, 2010
No Power. Blown fuse or dead power supply?
Replace the power supply. Definately not the fuser
Jul 23, 2017 | HP LaserJet 1200 Printer
No power. Checked outlet, which is fine. Plug into the printer is in all the way. It was working this morning and now nothing.
It sounds like the fuse on your power supply is burned or the power supply board itself needs replacement.
Jan 13, 2011 | Konica Minolta Magicolor 2530 DL Laser...
I plugged it into 220V outlet and Brother HL 2140 only accepted 110-120V. Is there a fuse somewhere I can access and replace? THank you.
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 28, 2010 | Brother HL 2140 Laser Printer
I have a MP600 printer. Yesterday it worked fine. Today it's dead. Not a sign of life. Replaced fuse in mains plug. Swopped mains cable for another. Still dead. Is there an internal fuse that may have...
Hi there!Had the same thing and after replacing the main board it sorted the problem out!Could have been a spike in power and also a dry joint on the board,It will be cheaper replacing the printer than replacing the main board!Sorry!!
Oct 20, 2010 | Canon Office Equipment & Supplies
After a brief power outage during a thunderstorm my canon i9900 will not turn on. I left it un pluged for several hours and then repluged it and still nothing. Everything else in the office works fine.
The power supply of your printer are damage due to the brief power output during the thunderstorm. Just check the fuse inside of the power supply of the printer if they have some burned or else use the Multi Tester to identify that the fuse are damage or needed for replacement.
Jun 03, 2010 | Canon i9900 InkJet Photo Printer
Microwave suddenly died in the middle of cooking
The only 2 user replacable parts in a microwave are the lightbulb,
and the 20 amp ceramic fuse. if you have checked the power cord outlet it's pluged into and both are fine. It's possabbe the fuse behind the controls is bad. Theese fuses look the old car fuses only
not made of glass they use white ceramic. A philips screwdriver will normally remove the outer shell of the microwave make shure it's not plugged in! After removing the outer shell look behind the controls on one of the power lines there will be a snap in fuse the above mentioned removal is easy it will pop right out replacment is oppsite of removal. If the fuse is bad replacing it cost about $3
warning don't mess with any thing else if you do this!!! microwaves contain radioactive meteral If you don't think you can do it safely take it to a pro or buy a new one
Hope This Helps gota lot of good years out of microwaves by changing those fuses. Most people just throw them away microwaves that is
If this helps ya
please leave feedback
Nov 19, 2009 | Dryers
Electrical storm last night. Now no power on
you need a power supply. That is where the fuses are and you should not replace them.
The Power Supply should be replaced.
Jun 12, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Left and right brake light doesn't work but center lights does
check behind the brake peadle for a little button that pushes in and out when the peadle is pressed(this is your brake light switch) some cars have more than one of theese. manualy let the button out if the light works the switch is good if it does not disconect the harness from the switch and take a small piece of wire and jump the two prongs on the harness if the brake lights come on then you need a brake light switch. if this doesnt work check for power at the switch. if no power you have a bad fuse if there is power and you already jumped the wires to the switch then you have a broken wire between the switch and the tail lights.
Dec 25, 2008 | 2001 Oldsmobile Alero
No power
Sounds like you have a fuse out on the engine control board (PCB) or it needs to be replaced. If you have a meter, turn the printer off and Ohm the fuses with a meter. If they Ohm, the Engine Control board (PCB) needs to be replaced. If they don't, change the fuse.
May 30, 2008 | Samsung ML-3561N Laser Printer
Front panel off
a lot of theese ranges have whats called a thermal fuse or tco that will open when the oven goes into an over heat condition i don't have access to sharps data but if you call you local appliance parts store they can look it up for you and tell you where it is youll have to buy a new one any way
Jan 26, 2008 | Kitchen Ranges
Lexmark X6180 Printer Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
