Question about Nikon Coolpix L11 Digital Camera
The camera turns itself of straight after being turned on, i have changed the battery
Camera turns itself off
or this problem try the following:
* Try removing the memory card and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 SAMSUNG
Hope this will help
Thanks
Byron
Sep 25, 2009 | Samsung NV3 Digital Camera
SHUTS OFF BY ITSELF
yes,, when we charge the battery for a longtime. the battery's will automatically decrease, this is the reason the camera is getting turned off by itself, change your battery to make it work well.,, thank you.. plzzz rate me,,,
Jun 29, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
My sanyo vpcs1080bl turn itself off when powering on
Maybe the battery is dead. change the right battery
Jun 20, 2009 | Sanyo Xacti VPC-T700 Digital Camera
DIGITAL CAMERAS HDC571 i WAS GIVEN THIS FOR CHRISTMAS 07 AND PRIOR TO THIS WEEK HAVE USED IT ONCE BEFORE. tHE BATTERIES SUPPLIED RAN OUT SHOWED NO POWER ON THE SCREEN SO I HAVE REPLACED THEM. i HAVE...
The camera uses a TFTLCD monitor, which is a high power usage device, any battery that are not high power will have the same results as you do (I have the same camera and done the same with cheaper batterys).
I will say go to a supermarket as mostr do Duracell turbo/ultras on 2for1 offers or 8 battery packs at half price.
Aug 23, 2008 | Hitachi Cameras
Samsun s630 lens is stuck out, won't turn on
guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Apr 19, 2008 | Samsung Digimax S630 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Stuck on change batteries
it seems that the camera section is haveing troube, may be in the lense movement or initilizing system. if the camera does not initilizes while swithcing on it turns itself off by giving low battery warning.
Nov 01, 2006 | Canon PowerShot A520 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
