Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Wont drain - Whirlpool Cabrio WTW6600SBT Top Load Washer
    Sergeant:
  • 197 Answers
Check pump/ hoses for blockages etc. also could be caron brushes on motor
Posted on Sep 28, 2009
Wont drain..door locked..what do l do?
put drain hose below water level when empty should spin
Apr 17, 2015 | Washing Machines
Why wont my washer drain drain
Probably the pump is stopped up or gone bad . Replace
Nov 20, 2014 | Washing Machines
Ge profile dishwasher wont drain. i have already replaced the drain motor. Why wont it drain completely
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 12, 2010 | GE Dishwashers
My washer wont drain it goes thru all the cycles but wont drain. at first with clothes in it it would drain onto the ground and not thru the drain pipe. took the front cover off to see where it was leaking...
Sounds like the drain pump has failed. Try to turn the impeller to see if it is bound-up. It may just be debris blocking the rotation of the motor. Is there a filter that has plugged?
Feb 10, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Wont drain
1)block in the drain hose.(check the hose of tank to drain connection)
2)problem in the drain pump.
Jan 08, 2010 | GE 24 in. Profile PDW7800 Built-in...
MASHER MAH5500BWW WONT DRAIN
this unit has a electric drain moter open the machine front . under the tub remove the drain hose and look for the a blockage if none present replace the whole drain pump assembly
Jul 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dishwaher wont drain-checked drain hose and its clean
The problem is most likely the drain valve. It is electrically operated and with your problem it is the most common cause.
If you need more help, post a comment.
Thanks,
Tim
May 29, 2009 | Kenmore 16719 Dishwasher
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
125 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
