Question about GE Spectra JBP78 Electric Kitchen Range
Burner on stovetop is out
Our front right burner (the one that can be small or large) the outer burner (the larger one) is dead. The inner one still works. How much is that outer burner part?
  • chris335 Nov 30, 2009
    still have not done anything...just been working around it.
    we've considered replacing everything with stainless steel. until we decide we don't want to spend $100-$150 (that's a guess) to fix it and then turn around and replace all our appliances.
  • 5wbfoleys May 11, 2010
    The same thing just happened to us with the same one. What did you end up doing?
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Large triple burner on right works on outer burners but inner burner will not come on??
Computer controlled. You need a technician. (I avoid buying appliances like that, like I avoid the plague). God Bless (and long live) the older appliances with knobs and thermostats!
Oct 08, 2012 | Ovens
Our Uniflame Grill has a round outer burner and a round inner burner. The outer burner has a large orange/yellow fllame. The inner burner has a small blue flame. Is it normal for the inner burner to...
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Jun 27, 2011 | Uniflame FG2204C Grill
My GE profile electric range (model PS905SPSS) has a power boil burner with dual burner elements (one inner circle and one large outer circle). The outer circle one is glowing and heating but the inner...
Disconnect power to range. If you have an ohm meter, you can check the burner coils for continuity from the wires at the switch. If not, open oven door, remove screws holding top. Lift up top and remove screws holding the set of burners in question and visually inspect the inner coil for a break in the burner coil.
Nov 27, 2010 | GE Ovens
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
The flame on my gas stovetop won't get larger
If this was not always the case then the orifice is partially plugged & needs cleaning.
If this was always the case then someone may have squashed the gas line when changing the orifice (perhaps to or from propane?). In this case you will need to change this part of the piping.
Dec 23, 2008 | Kitchen Ranges
GE Spectra JBP78 Electric Kitchen Range Logo
173 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
