Question about Brother HL-2040 Laser Printer
Printer has been working this morning, went to print another document and the paper light came on - has plenty of paper. Checked all three openings and see no problem. turned off and unplugged both power & data cable. Same problem, goes to green & then right to steady red paper light.
  • 11,896 Answers
Try using one paper at a time first, If it starts taking, then add other paper, The paper sensor may be faulty
Posted on Sep 28, 2009
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
R200 both red lights flashing
if both red lights are flashing alternately your printer has been locked this is due to full waste ink pads. you need to have them replaced either at your local service centre or do it yourself then you need a scss reset utility to reset your printer you can get a free one of these on the net
If your lights are flashing continuously look to see if you have any outstanding documents in your print queue and delete them
Mar 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Messege * load mp tray * but tray has plenty of
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
Nov 12, 2009 | Kyocera FS-2000D Laser Printer
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
My hp printer wont print a document and when i go to print it says it has 45 documents waiting. there is plenty ink and paper in the printer.
go to start>>control panel>> administrative tools>> services
search for "print spool" and any other listing related to the printer. stop the process by high light the service, right click on the mouse and stop.
open up the printer form start>>printer & faxes.
deleted all the print job that are in the queue.
go back to the service section above. and restart the services.
Jun 08, 2009 | HP PSC 1410v Printer
Brother 5250
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
  • May 27, 2008 | Brother HL 5250DN Laser Printer
    Paper LED Blinking
    Did you see http://www.fixya.com/support/r310860-lights_indicate
    The Paper LED is flashing.
    papereroor2.gif Meaning of LED Indication
    Front cover is open:
    Close the front cover of the printer.
    Back cover is open:
    Close the back cover of the printer.
    Paper jam:
    Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
    No paper fed manual feed slot:
    Put the paper back in the manual feed slot.
    Memory full:
    The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
    Print overrun:
    A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
    Clean drum unit:
    The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
    Jan 04, 2008 | Brother HL-2040 Laser Printer
    Paper Size Error
    Hi there check that the printer properties have not been changed.
    • Click Start
    • Select Printers and Faxes
    • Right hand click on printer icon
    • Select Printing preferences
    • Check that the paper size matches that you have got in the tray
    • OK and exit and test
    If the above doesn't work try the following
    • Open MS Word
    • Open the document that you are having problems with
    • Click File
    • Select Page Setup
    • Check that Paper Size is correct
    • OK close and test.
    This is normally a driver issue as the paper tray on the printer doesn't know what size paper is in it until you tell it from the driver.
    Hope this works for you
    Thanks J
    Dec 27, 2007 | HP DeskJet 5650 InkJet Printer
    Brother HL-5250DN printer paper light won't go off
    2. Hint
    Here's the link from HP, on how to open the Fuser Cover.
    http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000000/000026/faq000026_007.html?reg=eu&c=eu_ot&lang=en&prod=hl5250dn_all
    Oct 05, 2007 | Brother HL 5250DN Laser Printer
    Brother HL-2040 Laser Printer Logo
    57 people viewed this question
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Samyfam
    Samyfam
