Question about Lexmark X125 All-In-One InkJet Printer
The buttons do nothing
I have my X125 plugged into the wall, the usb connected to the computer and the line connected to a phone with a dial tone and I've downloaded new drivers. All I get is bars across the top of the window I'm not able to scan, the buttons do nothing
5 Suggested Answers
  • 23 Answers
SOURCE: Scanner - Scanning Bar Became Stuck
if the scanner bar is stuck in the center then U hav to call Lexmark tech support at 8003324120 & have them chk the warranty of the printer.. if its in warranty it can be replaced
Posted on Jun 19, 2008
SOURCE: need download from computer for my lexmark x125 printer-fax
This is my exact problem except I have a hp windows xp.
Thanks
Posted on Oct 09, 2008
ittbrad007
  • 38 Answers
SOURCE: My computer with Windows Vista doesn't recognize the Lexmark X125
http://downloads.lexmark.com/perl/downloads/downloads.cgi
The link above is the driver for that printer. Download that driver and then install it. Once you install it, the computer should recognize it.
Posted on Mar 26, 2009
arjoy
  • 95 Answers
SOURCE: telephone cable is connected and I have no dial
no.... i dont think usb cable and your phone jack will fit together.. causing your phone jack damage.
Posted on Jan 28, 2010
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Everything is working fine on my lexmark all-in-one except for the fax. It is dialing the number and says that it is connecting but will not connect. Have cut it off for a period of time then cut it back...
It could be the fax line in the wall. Try to insert a telephone straight to the wall and listen for a dial tone. If you hear no dial tone, please contact your phone company and have them check the line. If you hear a dial tone, re-plug the printer into the wall using a different known working telephone cable. Try to fax again.
Aug 26, 2011 | Lexmark X4250 All-In-One InkJet Printer
MY LEXMARK X125 STOPPED RECIEVING AND SENDING FAXES. IT HAS ITS OWN LINE NOT CONNECTED TO COMPUTER. ALSO MY SPEAKER DIAL TONE IS NOT WORKING. WHEN CHECKING MY DRPD WONT SET UP EITHER. THIS JUST HAPPENED 2...
Hello. If everything else is working, printing and copying, unplug the printer from the power source. Check the telephone line from your phone company by unplugging the fax machine from the wall jack where it is connected to. Plug a telephone device straight to that wall jack and check for a dial tone. If there's no dial tone, contact your phone company. If there is, plug the fax machine back to that wall jack. You can also try replacing the telephone cable with a another known working cable. Plug the printer back to the power source. Check again. Hope this helps.
Mar 23, 2010 | Lexmark X125 All-In-One InkJet Printer
Ux-p100 fax dont have a dial tone
Check your phone line by plugging a spare hanset into the wall socket (Incoming line) and listening for a dial tone on this. No dial tone - faulty line connection.
Also check you have plugged in to the correct socket on the back of your fax.
Dec 09, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
THE PHONE SAYS LINE IN USE
Check to see that you have dial tone from the phone company by using a standard non cordless phone. if you have dial tone then check the cordless phone and make sure you plug into the correct port and ensure that you have the power plugged into the wall. Also, use the same cord from the standard phone that is connected from the phone to the wall to ensure that your line cord is not bad.
May 29, 2009 | Panasonic KX-TG5672 Twin Cordless Phone
I am trying to use the fax facility on my epson600fw.my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a Canon MP830-All in one. It does everything except send/receive faxes. The line has been checked out. If I connect it to the phone line, it just clicks. I have rebooted and unplugged and...
Your fax machine is not getting a dial-tone.
Plug a regular phone into the wall jack and listen for a dial-tone
Make sure the phone line is hooked into the LINE port of your fax machine.
Unplug the power cord for 10 seconds.
Do you have a DSL phone line?
Oct 21, 2008 | Canon Office Equipment & Supplies
Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Problem with fax
I'm no expert but, did you try touching the online or hook button on the fax to hear the dial tone? Or connect a basic home phone into the phone jack at the wall the fax was plugged into. Do you get a dial tone. If no dial tone, call the phone company. If there is a dial tone, its the fax.
Nov 27, 2006 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark X125 All-In-One InkJet Printer Logo
12 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
