Question about Char-Broil Commercial Stainless Steel Grill
Regulator Repeatedly Reduces The Gas Flow
I have a Char-Broil comercial 4-burner grill model 463268007 running on a 20lb propane tank. After operating correctly for a short time, the regulator reduces the gas flow to a level at which the grill will not stay above 250 degrees. It happens almost every time we use the grill. I'm on my second regulator from Char-Broil (both cause the problem). I've changed tanks. I've unhooked the regulator and let it reset. What's causing this?
  • rahatfaraz May 11, 2010
    Solution chack on this site www.solve.tk
The new regulators will automatically shut down or reduce flow if the it senses that the flow is too high (as in a line leak or break). It can also be folled if you open the valve too quickly. There is a special plastic plug that can reset a tripped valve in the new tanks. (Mosquito Magnet supplies one with their product).
The other thing is that there is a recall going on at Char Broil of defective thermometers that are reading too low.
Posted on Nov 23, 2009
Cannot get and flame.see spark from starter new tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 27, 2014 | Char-Broil CharBroil 4638310 Grill
The burners will not light. It appears that they are no getting any propane from the tank. Unfortunately, I have missed the manuel and this is a brand new grill. First time trying to use it and have...
The problem is more than likely the OPD Valve in the gas tank. To solve this problem, turn the Tank Valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY,VERY SLOWLY (Slow motion, slow). Once it's fully open, light the burner farthest from the tank first and turn it to it's highest setting. Does the flame height look correct? If so, light the remaining burners following the same procedure. Now, to all the flame heights look correct? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly. If it didn't solve the problem, make sure you have adequate gas in "old propane tank from the other grill."
To further help you, I have included a link to your Owner's Manual that you can download and print for future reference. http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463247310%20english.pdf
In addition, here is a link to Troubleshooting Gas grills
http://www.charbroil.com/Support/Troubleshooting_Level2/4/Gas-Grills.aspx?Model=463247310
I really hope all of this information has helped you solve the problem. Please let me know and Happy Grilling.
May 22, 2011 | Char-Broil Grilling
How do youremove and replace a charbroil gas grill burner on model number 463268007
Here is a link to the Owners Manual for your model grill. It has the assembly instructions, so just reverse what they are and you'll be in business. As they say, "one picture is worth a thousand words."
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463268007%20manual%20-%20english_3d4c7147-c_.pdf
Apr 03, 2011 | Char-Broil Grilling
New propane tank won't ignite
The regulator on the on the hose is either gone bad, or could have got a little bit of dirt in it. You could tap the side of the regulator gently and sometimes this will solve it.
Apr 11, 2010 | Char-Broil Designer 463261106 Grill
Will not produce high flame properly
You probably have a bad regulator which you can buy at most stores that sell BBQ's.
Apr 07, 2010 | Char-Broil Performance 463463006
My char-broil patio grill doesn't get any propane to the burner. The tank is full only used the grill 4 times #07601295
Hello. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Turn the burners on for a minute and then off with the regulator and hose off the tank, then hook it back up and very slowly oven the tank. Then fire off the burners.
In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
Mar 15, 2010 | Grilling
I bought a large 5 burner unit 5 years ago.
There are a few things you can check.
1. The burner could be rusted and needs cleaned or repaired.
2. A spider or other insect has built a web in the inlets of the burners.
3. If you are using a 20lb propane tank, it could be overfilled.
4. If you turn off your grill using the propane tank valve and not the valves on the control panel, it may cause the overfill protection device to engage and decrease gas flow.
5. The regulator could be faulty.
6. The jets(orifices) where the gas comes out may be sized to small or may be clogged.
Mar 03, 2010 | Grilling
I can't get the grill to light....can you help me?
If you have 20lb gas tank, you could try opening the bottle really slowly. The newer tanks are equipped with a device called OPD, which means, overfill protection device, so when you take it to be refilled the filling station can't over fill it. However, if you open the tank too fast, it will cause this device to restrict the gas flow to the grill.
Nov 14, 2009 | Char-Broil Advantage 463453306
Char-Broil Commercial Stainless Steel Grill Logo
309 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Jim Thurston
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
