Question about HP OfficeJet 6110 All-In-One InkJet Printer
No copying from auto feed or flatbed even though ink cartridges check okay
Printer error comes up "Remove and check color cartridge". Have done this and it won't clear. I am not even using color ink...what do I do?
Hi
There are two main reasons for this problem, one is that the colour cartridge has insufficient ink in it, even if not showing as such, and the other is that the cartridge is a compatible, and not being recognised, this can be the case even though the cartridge was accepted originally. Its worth noting that many printers will not print unless all cartridges are in full working order, even if the non-working cartridge is not required for the print job that is wanted.
I found a full manual here:
http://h10032.www1.hp.com/ctg/Manual/c00369567.pdf
which has some useful information about troubleshooting such issues.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 04, 2015 | HP OfficeJet 7210 All in One Multifunction...
I have a Canon MX700 and suddenly I began to have problems with the color. I am using Canon ink cartridges but all my color jobs come out with only blue and black, no magenta or yellow. Every time I run...
This worked for me:
Unplug (not just turn off) the printer. Wait at least 20 seconds, then plug it back in. Hold the Feed Switch down, then turn on the printer (continue to hold the Feed Switch down). When the printer finishes cycling the paper feed, release the Feed Switch. Copy anything and it should print. You're good to go.
Oct 01, 2013 | Canon PIXMA MX700 All-In-One InkJet...
Just replaced ink cartridge and still says cjeck ink and it will not print
did you get a brand name canon pg40 or pg 50 ink cartridge, i replaced the one at works black cartridge with an eco refilled cartridge and it still showed up empty even though i know it wasn't. its canons way of making sure you buy canon. there are ways around it though. hit menu navigate to "rx settings" hit okay then hit okay on "autoprint rx" make sure it is set to on and hit okay, then make sure "print when no ink" is also set to on and hit okay again. it will now automatically print even if the machine thinks there is little or no ink. cheaper knock off cartridges here we come!
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Hi I've got an epson stylus dx4400 printer. The printer is a little strange because two of the ink cartridges are reading full, even though one of them is completley empty and the other is about a quater...
There is no sensor that reads actual quantity of the ink in the printer. The measurements are based on calculations how many pages are printed and what has been printed after last ink cartridge replacement. Probably the printer has been tricked that there is a new ink cartridge, but there is the old one.
Often a small object can fall in the paper tray and go down the paper path, preventig paper from picking up and moving. Rotate the printer with the front side up and try with thin and long flat skrewdriver to rise the thin long rollers that hold the paper to the feed roller, one after another. These rollers are held there by springs. If someting is stuck behind them, it should fall down. I've found there coins, pensils, rullers, paper-clips and so on.
Jun 15, 2010 | Office Equipment & Supplies
We have a Sharp 1641CS copier will not feed or copy
Well one reason the Cartirdge is spilling is due to the cartridge backing up with toner everytime it tries to print, it misfeeds cause the paper feed tires need to be replaced,
May 29, 2009 | Sharp AL-1641CS Copier
My printer will feed paper, but no ink is printed..
i im  josh in cebu phils.may i help you? Friend the printer that prints and without ink appears even though not run out of supply. the problem is not the ink  but the tank lever that carries the cartridge.there maybe stuck dried ink on it came from previous ink installed that drain on the lever. Solutions: 1. try to remove all the ink and clean the lever with a soft cloth. 2. go to settings and perform the head cleaning and nozzle check. 3. do the printing repeatedly until the ink comes out. thats all friend good luck hope i helped you.
Mar 14, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Message: Intall new ink cartridge. Ink Low
When you hear the fax ringing, press the start button. It sounds like you are not set to AUTO RECEIVE
Jan 20, 2009 | HP 1040 Plain Paper Inkjet Fax
Printer will not work. Error E3
What may have happened is that the Paper sensor is locked down and tells the printer that there is paper in the path (although there isn't any). The paper sensor is a toggle switch and there is a paddle that pushes it down as the paper goes in/out. Look on the right side of the unit ,under the roller assembly. Sorry, but I do not have a service manual for this unit.
Error list :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP380 Copying problems
what happens when you make a copy from the glass (bot the doc feeder), or a print..
if this happens only when using the Doc Feed.
Look at the Slit_Glass, if there is drit on it, clean it, and try again?
Could also be the ink is leaking in the machine? clean the ink cartridges and where the Ink Cartridges are inserted.
Oct 27, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
