Question about AT&T Blackberry Curve 8300 Smartphone
The battery goes from full charge down to power off in about 2 hours. Is it a phone problem or battery problem. No other ohne concerns.
  • 61 Answers
It may be a battery problem just examin the battery whether it is in normal shape or not
Posted on Sep 28, 2009
Phone goes off and will not come back on.put new battery in and charged for 5 hours still same problem
Try pressing and holding vol up+ power or vol down + power for about 10 seconds. vold up+home+power is an alternative depending what phone it is. If not it's most likely fried or screen went out
Jan 30, 2015 | Samsung Cell Phones
My battery on my iphone runs out in 2 to 3 hours. What to do?
I think you must check your charger and if ok replace your battery
Mar 31, 2008 | Cell Phones
Samsung galaxys 2 drain battery fast
The power cell should only get warm if you have it powered on all of the time. That is natural. 6 hours is short, and that may be one of two problems, the time of charge is too short, or the battery is dying. HINT! If you replace with a NEW battery; you must set the battery memory for the start. That means, when you first charge it, make certain it gets a long 24 hour charge to full. Use the phone until the device shuts down because the battery was exhausted. Now Do a full long term Charge. That process will set a Memory for the Power Cell and allow you to fully charge and discharge the battery from there on. One more thing...if you use a Charger Device, make certain it is working OK or else the Battery will not charge well.
Dec 12, 2013 | Samsung Galaxy Tab 2 7.0
My phone will not charge. I can connect it to the charger and it looks like it is charging. Remove the charger then phone goes off. I charged the battery with a stand alone charger then installed battery....
It maybe a problem on the phone already and not on the battery. Something inside the power ic / board that's why any battery will not hold charge for long. Try also draining the battery and then charging it for a full 2 hours with the phone powered off as this charges the phone faster.
Mar 07, 2011 | Motorola Mobility MOTORAZR2 V9 Cellular...
My Sony Ericsson K810i Mobile have a problem. It shows the charge indicator nearby 99 % and if i speak a cll it goes very low and says 'attention Battery Low' and if i leave the phone to standby it shows...
Hi, problem can be solved. When a phone battery indicates 99 % of battery life and runs down so quickly, it is caused by damaged battery.
When a battery cell is damaged, it will display charging full but itwill empty. You will need to replace the battery for a better battery performance.
When a new battery is been purchase, make sure it is charge it is charge up to 4 to 5 hours before use.
Oct 13, 2010 | Sony Ericsson Cell Phones
Battery goes empty after full charge
Hi,when a battery goes empty after fully charged, means the cell of the battery is weak and can power on the phone for too long.
All you need to do is to replace the battery with another one,charge for about 6 hours before use and every thing will work fine.
Oct 05, 2010 | HTC BH M300 Bluetooth Mono Headset (UK...
3 month old new phone. samsung tocco lite. battery problem
1) faulty battery - you'd need to get a replacement from the manufacturer (should be free if still under warranty)
2) when you initially charged the battery after purchasing, if you used it at all before it was completely charged it won't hold a charge.
3) if you live or travel in mountain area, phones lose battery power quicker due to an increase in elevation and distance from nearest tower.
4) if phone has been exposed to moisture or direct sunlight for an extended amount of time, it can damage the phone's ability to hold a charge.
honestly, your best bet is to replace the battery & allow it to charge for 24 hours in "off mode". if the problem persists, then send it in to be repaired.
Mar 19, 2010 | Lands Phones
Phone shows full battery then goes dead in an hour.
If you turn your phone on the very first time you use it you are suppoesed to charge it for ten hours. or not quite ten but what I do is i charge it all night and turn it off. this way you get sleep and in the morning your phone should be fine. if not reset the settings this should do it.
Jul 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
Battery goes down so fast. nokia n91
the problem may be one of 3
1-imagenary charging
2-bad battery
for the first one try another battery and charger
and for the second just try your battery on any phone
3- the problem in the Main board (Tahvo component)contact anyservice point
May 03, 2009 | Nokia N91 Cellular Phone
HTC S710 - Battery issue
it could be either battery or charger, If the charger isn't supplying enough power it will fool the phone..
some 3rd party batteries and cheapo chargers can cause all sorts of problems like this.
best way to test is charge your phone by usb, it takes longer but will give you some idea of weather its the battery or charger.
Make sure that the box at the bottom of the power management window (dont charge by usb) is set to off. Also for best results remove any other usb devices from the computer this will leave more power for the phone.
Best of luck
Jun 05, 2008 | HTC S710 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
62 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
