Question about Canon PIXMA MX310 All-In-One Printer
When trying to print I receive a not online message. power is on and cable is attached. the printer was online earlier that day. what else can i do?
2 Suggested Answers
  • 5101 Answers
SOURCE: Canon Pixma ip3600 message saying printer is not online
This could be a problem with the port. If you have the printer attached to a USB hub, directly connect to the computer. Try connecting to a different USB port and test the current port with a known working device. Consider trying a new USB cable (minor damage could be a factor in signal loss).
I hope this helps.
Posted on Feb 04, 2010
Testimonial: "Thank you,I did replace the USB cable and all is well."
Not able to print from computer after paper outer jam message.
If happening after update, try system restore and go back to an earlier date. Try printer, if OK there is an update causing issue and should be avoided. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Aug 27, 2014 | Epson TX700W Series
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
When I try to print I get the message that the printer is off line.
Please confirm your printer is plugged in and powered on. Next you should check your printer cable. If well plugged in and the the offline message persists, the you should try another printer cable, you know is working well. The fact is everything points to your printer cable if the printer is powered on. You may also go to your printer folder and right click on your printer icon th see in the pop up menu for any options for online/offline. If you see any select online. Otherwise you need to try another cable.
Good luck & God bless!
Nov 13, 2010 | Epson Stylus NX515 All-In-One InkJet...
I own the HP Photosmart 3210 all in one printer scanner copier. I am getting the message 0xc18a0401 and cannot resolve with methods online with hp or separate.
Please try to perform the steps as given it will resolve your issues------>
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Aug 18, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error message 0xc18a0201
try to reinstall your printer and if the error message show up again try to check your printer to the HP customer care mybe the problem from your board printer
Apr 09, 2010 | HP Photosmart C5180 All-In-One InkJet...
My printer will not print. One day it was fine the next day it has power but it won't work.
Try going into Start > Accessories > System Tools > System Restore > Restore to an earlier time when it was working.
Dec 01, 2009 | HP Photosmart D7160 InkJet Printer
Printer message says it is offline
Hi
Kindly check the usb cable if its fine then try going into control panel open printer and faxes option & set your printer as default .
Thanks
Jan 03, 2009 | Brother HL 2140 Laser Printer
Not printing
Hi ,
There may be several causes for this problem.
I will tell you one by one, and you try it.
CAUSE: 1
The printer is not
receiving power.
SOLUTION:1
Check the power cord connections.
Check the power switch and the
power source.
CAUSE:2
The printer is not
selected as the
default printer.
SOLUTION:2
Select Xerox Phaser 6110
Series as your default printer.
CAUSE:3
Check the printer for
the following:
• The printer cover is
not closed.
• Paper is jammed.
• No paper is loaded.
• A toner cartridge is
not installed.
SOLUTION:3
After locating the problem, clear it.
If a printer system error occurs,
contact your service representative.
• Close the printer cover.
• Clear the paper jam.
• Load paper.
• Install the toner cartridge.
CAUSE:4
The printer may be in
manual feed mode
and out of paper.
SOLUTION:4
Check the message on the Status
Monitor program window, add paper
to the tray and press the
button on the control panel.
CAUSE:5
The connection cable
between the
computer and the
printer is not
connected properly.
SOLUTION:5
Disconnect the printer cable and
reconnect it.
CAUSE:6
between the
computer and the
printer is defective.
SOLUTION:6
If possible, attach the cable to
another computer that is working
properly and try to print a
document. You can also try using a
different printer cable.
CAUSE:7
The port setting is
incorrect.
SOLUTION:7
Check the Windows printer setting
to make sure that the print job is
sent to the correct port. If the
computer has more than one port,
make sure that the printer is
attached to the correct one.
CAUSE:8
The printer may be
configured
incorrectly.
SOLUTION:8
Check the printer properties to
ensure that all of the print settings
are correct.
If u still cant find the remedy, go for the support from XEROX,
www.office.xerox.com/printers/color-printers/phaser-6110/serv-enus.html
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | Xerox Phaser 7760/YDX Laser Printer
I am having difficulty printing, receiving error message #1201 which is not in the manual. Re: Lexmark FAx X4270 Please provide me with a suggestion.
Hi teri,
I've seen this before and I know that once it was fixed by cycling the power a certain way. Try this:
1) Turn the printer off.
2) Unplug all of the cables.
3) Plug the power cable back in.
4) Turn the printer back on.
5) If the 1201 message on the Control Panel comes back up, try plugging the printer directly into the wall or into a different power strip. If no error message, plug the USB cable back into the printer and try printing.
It could also be a faulty AC adapter - if you have access to another compatible AC adapter try that. If the message continues, then the printer is probably defective and you should check your warranty status.
Please let me know what you come up with.
Ben
Mar 13, 2008 | Computers & Internet
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
