Question about HP TouchSmart IQ770 PC Desktop
I just got a new computer and the f3 key is not working.
  • rahatfaraz May 11, 2010
    Solution chack on this site www.solve.tk
    Problem Solver:
  • 5 Answers
Chances are it's the keyboard. If you are still using the old PS/2 connector for your keyboard, check where it plugs into the computer for broken or bent pins. Chances are it is probably USB though, in which case the problem is probably an electrical fault or loose contact in the keyboard it's really not worth fixing, buy a new one. They're extremely cheap nowadays; Under R100 / $5-10
Posted on Sep 30, 2009
PXE-E61 Media test failure, check cable
YOUR NEW HARDDRIVE SATA THEY HAVE A BAD SECTOR. UNEED TO CHECK DISK TO OTHER COMPUTER OR HDD REPAIR FOR FIXING THE BADSECTOR THE ACCESS UR HARDDRIVE. TTHEN PUT BACK TO YOUR COMPUTER AND THEN TRY TO PORMAT AGAIN IN XP OR OTHER WINDOWS OS.. TRY TNX
Nov 18, 2013 | MSI Wind U123-002US Netbook
How do I find the permutations button on a Casio Computer FX-CG10 Graphing Calculator
Turn calculator ON.
If you see no icons, press the Menu key then [1] to select Run/Mat.
In Run/Mat press the OPTN key, then the F6 key to pan other tabs.
Above the F3 key you see the PROB tab. Activate it by pressing F3. The permutation Tab is above F2.
To use permutations, enter the larger number (n), press F2 [nPr] followed by the smaller number.
Jan 31, 2013 | Casio Computer FX-CG10 Graphing Calculator
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
I cant use f3 key to disable battery charging for dell inspiron m101z.
You have to Press and Hold the FN function key at the lower left portion of the keyboard, then hit the F3 key. Hitting the F3 key alone will do nothing.
May 18, 2012 | Dell Inspiron M101z Laptop Computer (AMD...
I have vx510 and i cannot dial up to server how can i setup the phone number on the vx510 to dial the server and how to configure.
SYS MODE EDIT G6 PASSWORD:Key in 1, Alpha, Alpha, 66831 and press [Enter]:SYS MODE EDIT G 6
FILE CONFIG.SYS_Press [Enter].SYS MODE EDIT KEY
*GO Key [F2]
F:IMM.OUT________ Value [F3]
Press [Enter] until you come to Phone1. Or select Key [F2] and enter Phone1 and press [Enter]. You may then have to acknowledge a new key.SYS MODE EDIT KEY
PHONE1 Key [F2]
9,18884659020 Value [F3]
Select Value [F3]. SYS MODE EDIT G 6
VALUEUse the Yellow [Backspace] key to clear out any value, key in the Authorization Number ( THE PHONE # HERE) and press [Enter].SYS MODE EDIT KEY
*GO Key [F2]
Press [Enter] until you come to Phone2. Or select Key [F2] and enter Phone2 and press [Enter]. You may then have to acknowledge a new key.SYS MODE EDIT KEY
PHONE2 Key [F2]
9,18886032312 Value [F3]
VALUE
9,18886032312____
_________________Use the Yellow [Backspace] key to clear out any value, key in the Authorization Number ( PHONE # HERE and press [Enter].SYS MODE EDIT KEY
*GO Key [F2]
Press the Red [X] key 2 times.SYS MODE MENU 3
CONFIG INFO [F2]
EDIT [F3]
PASSWORDS [F4]
Select the up arrow at the bottom of the display 2 times.SYS MODE MENU 1
CONTRAST [F2]
CLOCK [F3]
RESTART [F4]
Select Restart [F4]. I HOPE THIS HELP : - )
9,18884659020____
Apr 11, 2011 | VeriFone Omni 3700
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
Swithcing from laptop screen to lcd monitor
Hi
Connect the monitor, flat panel, or projector to the laptop's 15-pin video connection on the back of the computer as shown to the right. Once connected, your laptop may automatically switch to the new external display or you may be required to press a sequence of keys in order to switch from the laptop to the external display. video.gif For example, often either Fn + F3, Fn + F5, Fn + F8, or Fn + F9 is pressed to switch between alternate displays. So if your laptop was Fn + F3, pressing and holding both Fn and F3 at the same time would switch between displays. Often, the alternate key pressed in conjunction with the Fn key will be labeled as CRT/LCD and/or have a picture of a monitor on the key or close to the key. Unfortunately, the keys pressed to switch displays is dependent on the model and manufacturer of the laptop. If none of the above key sequences work, consult your laptop documentation or consult your laptop manufacturer.
Some laptops also have the ability to have the display on both the laptop and external display and/or one or the other at a single time. Laptops with this ability can switch between these modes by continuing to press the same function keys until in the mode the user wants.
Feb 01, 2009 | HP Pavilion dv6000z Notebook
HP TouchSmart IQ770 PC Desktop Logo
42 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
