Question about Kodak ESP 5 Printer
Have to play around with the on/off switch to get the printer to come on
  • 295 Answers
Make sure that there is light on the Power cable.You have to press the on/off button for only 5-10 seconds to turn the printer on.If issue persists,call Kodak at 1800 421 6699 and your printer will be replaced by Kodak free of cost.Enjoy happy printing. :-)
Posted on Oct 10, 2009
Multipurpose tray not recognizing paper is loaded
the kill switch that contacts with loaded paper is not working or rather not having contact with loaded paper tray ensure it does and the printer will recognize a loaded paper tray
Jul 11, 2013 | Minolta magicolor 2200 DeskLaser Printer
Canon c2020h
Hi.Look in preferances for quick setup, u will find duplex printing , tick this box and u will get two sided printing. If your printer does not turn the paper follow the prompts on screen. Play around and u will be amazed at what canon printers can do for u ..
May 17, 2013 | Office Equipment & Supplies
This may sound REALLY stupid but...how do you switch off the printer instead of using the main switch on the side of the printer? (I'm using HL 2142 Brother Laser Printer)
I plug my printer into a power strip that has its own switch. This saves on having to reach around the printer to get to the regular switch.
Aug 03, 2010 | Brother HL 2140 Laser Printer
Dell 3000cn front door open error
Check to make sure the door if fully closed and that your photoconductor unit is installed correctly.
When you close doors on your printer there are tabs that push a switch to tell the printer the door is closed.
locate the switches and play around with it, push the switch in and out with a flat screwdriver.
Worst case scenario is you will need to replace the switch.
Mar 31, 2010 | Dell 3000cn Laser Printer
My foglights wont come on is there a separate switch
Ther prob is, you can try and trace the wires from the lights to the switch or just look around and see if there's an odd switch sitting there. Other possibilty is its integrated into the parking or headlights. Try playing around with your turn signal switch, usually has a fog light feature on them.
Good luck to you.
Feb 03, 2010 | 2004 Dodge Intrepid
Microswitch that detects out-of-paper seems to be working in reverse. With no paper loaded, depressing the switch gives an alarm. Release the switch and the printer will go online.
if you have ever tried to disassemble the micro switch, chances are you might replace the connector the other way around, if not then the problem is the micro switch itself.
Nov 19, 2009 | OKI MICROLINE ML-395 Matrix Printer
No power to cab, no power to start, but clock has power
check fuse block for shorts, melting discoloring,on back side of fuse panel around starter relay. loose connection causes fuse block to over heat will need to be replaced.hope this helps.
Oct 29, 2009 | 1997 Chevrolet S-10 Pickup
Konika Minolta 2400W can not connect. Clearly Windows XP sees it, and the driver is installed etc. When I plug or unplug the USB cable, Windows plug 'n play notices the difference. And the USB cable works...
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Jul 19, 2009 | Minolta magicolor 2400W Laser Printer
No sound out of 4 of 5 speakers when using tv only.
switch around rca cords and verify its not a bad wire(s),Check and see in the TV menu audio settings are correct/ balances R/L etc. audio outputs are on,Try different theater amp if you have an extra.
Jan 26, 2009 | Samsung HT-X50 System
Kodak ESP 5 Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
