Question about Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive
Power supply Adaptor
Usually when the hard drive is running the adaptor seems to die and wont come back on till the adaptor is unplugged, sometimes when not plugged up to the hard drive it dies until unplugged, i want to know if this problem is fixable because i cannot afford a new adaptor for it yet. This has started happening today just a few days after the warranty ran out grrr.
  • Jonathon summesfield Dec 18, 2007
    It was the power supply . Its okay now , there was a loose connection on the input of the adaptor .. thanks for the help anyways. Might go buy a new one next year once christmas is out of the way.
  • 42 Answers
Just to be sure, is it the power supply that is faulty, or the harddrive 'case'?
If you have a separate power supply, you can find a new one for something like 15-20$
/michael
why pay for software?
Posted on Dec 18, 2007
Seagate external hard drive usb and power adaptor
any power adaptor would do it as long as the voltage is good (usually 12v) and amperes is the same or higher than what's written in your hard drive enclosure (usually 1Ampere = 1000mA) is good enough, some HDDs use up to 2000mA
Usb cable is very easy to find
you can find those at any electronic parts selling or ebay
Please rate
Jul 18, 2013 | Computers & Internet
When i connect my laptop power pack/adaptor to a source of light the power light on the power pack comes on, but when i connect plug in the power pack/adaptor pin to the power inlet port at the back of the...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 17, 2011 | Computers & Internet
I have just been given a Maxtor 750gb separate hard drive but it has no power adaptor. Would i be able to use an adaptor from my 500gb Maxtor separate hard drive or will i have to purchase a new power...
By SEPARATE I am taking that to mean an external drive and not an internal mounted drive. If IT IS external the same power supply should work fine as the drive motors are the same in both models. IF IT IS Internal then the question is whether your power supply is molex or ATA.
Jun 06, 2010 | Maxtor Hard Drive
My v2000 will not come on at all? I have it plugged in with the adapter and it's like there is no power to it at all?
check power supply adaptor and batteries if they are supplying enough power, if you can borrow a power adaptor and spare battery try replacing them with one your notebook has.
if it works then your adaptor and batter are out, normaly if the adaptor stops working the battery would have died down too as you would have not noted till the notebook totally died down.
Dec 07, 2009 | HP Compaq Presario V2000 Notebook
I can't find my adaptor/power supply cable. can
Most are 12V for the FreeAgent drives, like the power inside your pc.
Oct 12, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Packard Bell w3910 d - Doesn't charge or get power from AC adaptor.
Sorry to say, power supply for laptop is harder to repair then PC (but repair able). You will need to get access to the board.
Maybe get a standalone battery charger ?
May 15, 2008 | Computers & Internet
Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive Logo
74 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
