Question about Kitchen Appliances - Others
Switch won't go off
My switch is installed to control 4 incandesent bulbs in my livingroom. Last night one of the bulbs burnt out and now the switch won't turn off. Any advice?
  • 87 Answers
If the switch will not turn off,the switch contacts are probably weled closed, install new switch . hope this helps
Posted on Oct 02, 2009
Testimonial: "That's what the problem was; x10 confirmed but there's no way that a burnt bulb should wreck a switch!"
  • kbsmiles309 Oct 02, 2009
    any type of surge weather it be rapid switching, small voltage spikes, will cause it to go bad, a blown lamp @ any paticular time can and will junk your switch also. Not to argue but i have seen it before.
Brake lights dont turn on toyota rav 4, whats the problem?
Check the switch on the break peddle , thay can work loose or renewal good luck colin
Jul 05, 2017 | Toyota Cars & Trucks
Has 4 bulb capacity and for a long time only 2 of the 4 would work. The other two would blow out. Last week the replacement bulbs blew out as soon as we flipped the swith then there was a burn smell. ...
WAIT! Are you SURE the 98480-02 is burnt? This is part of the FAN circuits and NOT your lights?
But wait again! Here is ANOTHER Link complaining about LIGHTS and this FAN module (who knew!):
98480X Hunter Fan Control Switch Repair
(I know, their photo does NOT match your part)
IF it is burnt here is a replacement for under $9
https://www.lightingdirect.com/craftmade-4565uf-ceiling-fan-triple-capacitor/p3035848?uid=3035848
It's proper name is: "Hunter Fan model 98480X control switch".
Anthony
Sep 22, 2017 | Hunter Ceiling Fan Light Switch Control
Kendal fan/light remote UC7208T doesn't dim
If you have CFL bulbs they won't dim. There should be a switch to change remote from CFL to incandesant light inside the transmitter. You'll have to match settings with settings in receiver.
Nov 25, 2013 | Dryers
Lights flicker in circuit with dimmer switch
Dimmer gone bad.
Buy new dimmer.
Check total wattage of bulbs, and compare with watt rating of dimmer.
Check if dimmer feels warm
reduce watts in ceiling linghts
http://waterheatertimer.org/How-to-wire-3-way-dimmer.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 26, 2013 | Electrical Supplies
2006 VTX 1300c neutral light won't come on when in neutral and won't start@
Hi, Tommy and the usual suspects are:
1. Neutral light bulb burnt out.
2. Faulty neutral switch.
3. A loose bulb in the socket.
4. Faulty wiring from the neutral switch to the light.
5. If the neutral light stays on while the bike is in gear the wire from the light to the neutral switch is grounded.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1800C Neutral indicator light won come on bike won start
HONDA VTX 1300 NEUTRAL LIGHT PROBLEM FIXED
Honda VTX1300S Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VTX1300C VTX 2004 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 08, 2013 | 2006 Honda VTX 1300 C
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
2004 envoy xuv low beams dont work switched fuses 45 and 46 still nothing any ideas
Other possibilities are; the bulbs themselves, burnt or corroded bulb sockets, or a bad headlight selector switch.
Dec 11, 2011 | 2004 GMC Envoy
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
Dimmer turns on/off 3 spotlights but they wont dim
Questions to answer so I can answer/resolve your problem:
1) Is this a rotary style dimmer?
2) Is it a toggle or slider type?
3) Is this on a 3-way circuit (that has 2 or more switches that can turn the lights on or off)
4) Is this on a single switch circuit?
5) Is this a brand new dimmer switch?
6) Is this an old dimmer switch?
7) Are the light bulbs in the spots regular incandesant or halogen bulbs?
8) Are the light bulbs in the spots CFL (compact flouresent lamps)?
With this information, I can tell you what the problem is:
If you answer "YES" to #1, and or #6 then the dimmer is faulty and should be replaced.
If you answer "YES" to #8, then you have the wrong dimmer for the bulb type, as CFL's require a specific dimmer type in order to dim them.
Please provide some more info and maybe we can help you figure out what's wrong.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Leviton Electrical Supplies
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
