Question about Creative Labs I-Trigue 3220 Computer Speakers
Creative Labs Itrigue 3220speakers wont work, only thru headphone
I'm having trouble getting sound out of the speakers, Creative Labs I-Trigue 3220. They were working perfectly fine when I went to bed last night and now the only way I can hear anything is if I plug headphones into the volume and bass controller. Any help appreciated
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Suddenly, my speakers won't make
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 01, 2011
I want a volume control for Creative i-trigue 3400 speakers. Where can i get just that?
If you search the internet for Headphone Volume Control Adapter you should find some, or radioshack sells them:
http://www.radioshack.com/product/index.jsp?productId=2102975
May 31, 2011 | Creative Labs i-Trigue 3400 Computer...
Suddenly, my speakers won't make any sound. this morning they worked perfectly, and i've checked the input is fine (it works well when i plug headphones in the volume control) and if i plug my ipod, still...
also
hope this helps
Apr 01, 2011 | Creative Labs I-Trigue 3220 Computer...
Where can i find another one of the small white aux cables that the creative I-trigue 3400 comes with?
I see. I have a cable just like that! You can buy them many places, I have found amazon.com to be the cheapest.
Here is an example of the cable I have and it works great. This should work perfectly for connecting your iPod to your Creative speakers.
http://www.amazon.com/3-5mm-Male-Retractable-Cable/dp/B0026SGOCC/ref=sr_1_15?ie=UTF8&qid=1295894682&sr=8-15
Its 1.85 with free shipping! get a few. This should help. Please feel free to vote if it does.
Have a good one.
Jan 24, 2011 | Creative Labs ITrigue 3400 2.1 Speaker...
Have an I-TRIGUE 3600 2.1 speaker for my
re-install drivers 4 audio or change settings
Jul 16, 2010 | Creative Labs Inspire T3000 Computer...
Power is on. Computer is working fine and
it seems that there is some problem with driver ,,,check the driver ,,,,, update it............. it will work fine
Jul 03, 2010 | Creative Labs I-Trigue 3220 Computer...
No sound after connection? Power is on! Computer
Check your Sound Device if it is installed correctly
No Sound from External Speakers....only from Headset plug.
Hi, had same problem.... unscrew the remote and carefully remove the back end part of the stereo-connector (very careful !) it consists of a very small switch which moves sideways..... this switch is stuck into headphone-modus. Reassemble and it will work again
Note that speakers will work if you remove the switch
Apr 19, 2010 | Creative Labs I-Trigue L3800 Computer...
My Creative I-Trigue L3800 speakers have stopped working. The system receives power (the volume control lights up) but I am no longer getting any sound. I fear something may have blown but not sure what. I...
don't know but i'm in the same boat. the white connector on the subwoofer does not receive sound. either the left or the right speaker will work when plugged into the red female connectors but neither works with the right. fuse is all i can think of. know where to get one?
Oct 29, 2009 | Creative Labs I-Trigue L3800 Computer...
I-trigue 3600 No sound out of thespeakers, earphone jack is ok
I'm pretty sure the power stage is fused on these- check those first, they're mounted on the amp board inside.
Aug 12, 2009 | Creative Labs I-Trigue 3600 Computer...
Broken Volume control
the stereo jackbus is stuck in headphone modus
unscrew remote and open up back part of stereo-connector repar switch and reassemble
Apr 27, 2009 | Creative Labs I-Trigue L3500 Computer...
Creative Labs I-Trigue 3220 Computer Speakers Logo
73 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
