Question about Nikon D80 Digital Camera with 18-135mm Lens
Black dot on my images
I have cleand my lens, then changed lens and the black dot that appears in my images is still there. I tried cleaning the mirror and the upper image screen and the black dot still apears. I need to know how to get rid of this dot. It is in the camera body and not on the lens after extensive testing.
  • 291 Answers
You can carefully dust it off with an air puffer bulb if you remove the lens, put the camera in "M" and set the shutter speed to 8 seconds. Press the shutter release and gently blow air on the sensor after the mirror raises up. Make sure you're in a clean and dry area, kitchen tables do fine. You just need to be gentle.
If this doesn't dislodge the spec, then take it to a camera shop and have them clean it. They may need to send it to Nikon. You can do it yourself, but if you damage the filter that covers the sensor, you are in for a rather large repair bill. This is one of those "if you have to ask how, then you shouldn't do it" things.
Posted on Oct 02, 2009
    Brigadier General:
  • 11,967 Answers
Please...do not touch the mirror!!! The black dot is dust on the sensor. Google the words...digital camera sensor cleaning. You will get complete directions and where to buy the supplies.
Posted on Sep 28, 2009
Riso drum prints extra little black dots on page
The solutions on that problem is in the imaging unit like you just have to clean the lens of the camera since tiny dots are dust that is being scnned by the lens during master making process
May 16, 2013 | Riso RZ220 Duplicator
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
Black speck in images
Take a look at "The Low-Pass Filter" subsection of the "Caring for the Camera" section of the manual (page 105 in my copy). If you need a manual, you may download a copy here.
Mar 19, 2012 | Nikon D40 Digital Camera with G-II 18-55mm...
There is some black unremovable dots (not visible on sensor sirface). Is IMAGE DUST OFF REFERENCE DATA helpful to remove that black dust like dot from image? how can I use that feture?
Black, unremovable dots are probably bad pixels in the sensor. These are parts of the sensor that no longer react to light. If you don't see any issue looking through the viewfinder, then the sensor is messed up. Since you say you don't see anything on the surface, I assume the optical part of the camera is in tact. You can try cleaning the sensor - Menu - Setup - Clean Image Sensor - it certainly can't hurt.
Nov 06, 2010 | Nikon D70s Digital Camera
Canon power shot sd1000 black dot on lens
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Canon PowerShot SD1000 Digital Camera
Sony a100 distortion dots - Im getting several
If these are single pixels on the LCD screen, they are normal. From pg. 8 of the user's guide:
"The LCD monitor is manufactured using extremely high-precision technology so over 99.99% of the pixels are operational for effective use. However, there may be some tiny black points and/or bright points (white, red, blue or green in color) that constantly appear on the LCD monitor. These points are normal in the manufacturing process and do not affect the images in any way. "
This may also be helpful.
"images may trail across the LCD monitor in a cold location. This is not a malfunction. When turning on the camera in a cold location, the LCD monitor may become temporarily dark. "
May 03, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
Black Spot
It's probably a speck of dust on the image sensor behind the shutter. If you can't find the cleaning mode in the Menu, set the camera to the M setting and rotate the dial to Bulb. Press and hold the button while you blow the sensor ( blue/green glass ) - BE SURE NOT TO TOUCH THE SENSOR and don't let the shutter close while you're blowing the sensor.
If you're not comfortable doing it, most camera repair shops will do it while you wait.
Dec 17, 2008 | Nikon D100 Digital Camera
Won't Take Pictures
My nikon coolpix 4500 has the flashing red clock as well with the hands of the clock pointed to 9 oclock and a white dot on the oppostie side of the 9
Dec 28, 2007 | Cameras
Viewing planets and stars
The problem is you are way out of focus. Turn the focus knob alot, until the star image gets much much smaller. Keep going until it looks like a pin point or a star!. The spider vane and center black dot will disappear. This black dot is actually the secondary diagonal mirror reflection in the primary mirror. The peace signs are the secondary supports. Use the lowest power eye pieces. I would not use the Barlow lens that comes with this scope as it very poor quality. Also, using this high power with this small an aperature (tube diamter) & unstable mount will be very difficult indeed. Invest in some wide angle, long eye relief low power lens. Use these for a while before going to higher powers.
Nov 19, 2007 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Black particles on focusingscreen
If the specks are just on your viewfinder focussing screen, they won't be on your pics. If they're on both your pics and focussing screen, you need to find someone else to clean your camera. Cleaning either your CCD sensor or your screen yourself can leave scratches. Changing lenses often can suck dust into the inside if the body is dusty. Try another repair shop for thorough cleaning - it shouldn't cost more than $50.
Dec 17, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D80 Digital Camera with 18-135mm Lens Logo
141 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
