Question about Gateway FPD1760 17" LCD Monitor
Alguien tiene el controlador para monitor gateway lcd tft fpd1975w-mx
SOURCE: power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Posted on May 18, 2008
Bat1956
  • 585 Answers
SOURCE: my gateway monitor FPD1975W 19inch LCD won't turn
I have repaired similar FPD models. I have one of them on this very desk.
The GatewayFPDmodels develop problems after a couple or more years of use. Therepairsare fairly easy for the savvy technician. The power inverterboard inthe back of the monitor contains some capacitors, they may be470 and220 mfd or 680 mfd depending on when they were made, @ 10 16 or25volts, with a 105 deg. C temp rating. They go bad due to heatissuesand the currents they have to filter. Replacement of thecapacitorsusually restores operation. Use capacitorss of the sameratings as original for replacement.
Be advised, turning the monitor off when you are not using it will extend the life between these repairs.
Hope you find this helpful.
Posted on Apr 24, 2009
  • 120 Answers
SOURCE: my gateway fpd1975w tft lcd monitor does not work.
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
Posted on Jul 24, 2009
  • 555 Answers
SOURCE: Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Posted on Oct 09, 2009
SOURCE: my gateway FPD1975W 19 INCH LCD MONITOR DOEN'T
(thank you budmrtn) my monitor shut off..i went online looking for solutions gate way fpd1975w..i looked hard for about 2 hours..i found a common problem was with the power supply..(budmrtn) hit it on the head..i am not an electronic expert at all..i have a soldering gun..thats is..no testers..so i took the monitor apart and found the power supply was a seperate board..i took it out and looked at it and said hmm. do i throw the 180.00 monitor out or do i take a chance..i took the chance..i went to radio shack and bought 10 capacitors like (budmrtn) said i replaced them..if it did not work i was out 10 buck and i was going to throw it away..but well and behold..i replaced the capacitors..just the big ones not the round blue ones..and wala..new monitor..it worked..crazy i no..but it worked..and i have a 19 inch lcd that works and i was going to throw it away..if you need to know what i replaced email me and ill let you know..
Posted on Feb 01, 2010
Compaq com ergo
No hablo espanol. He utilizado el traductor de google para esto. la impresora funcionara sin el de software. Win8 puede encontrar los controladores en linea. El escaner funcionara a traves del panel de control, si tiene uno. Para instalar los controladores controlan gestor de paneles / dispositivo. (encontrar signos de exclamacion amarillo) haga clic derecho. elegir actualizar los controladores. Para ejecutar el control del escaner del panel / dispositivos e impresoras. encontrar la impresora. haga clic derecho y elegir exploracion.
Dec 02, 2013 | Computers & Internet
Mi ordenador no mme permite entrar a internet
Do you have a working network adaptor? Install the drivers to fix the problem
(Tiene un adaptador de red de trabajo? Instale los controladores para solucionar el problema.)
Aug 14, 2013 | Dell E197FP LCD Monitor
Where is the microphone
That model does not have a built in microphone, you will need to get an external mic and connect it to your computer.
May 08, 2012 | Gateway FPD1975W 19" LCD Monitor
He instalado windows 7 necesitaria drivers para este sistema operativo
Windows 7 busca autom?ticamente los controladores para el video. Usted no necesitaun controlador para el monitor.
Mar 09, 2011 | LG Flatron Ez T910B 19" CRT Monitor
Hola, tengo un controlador behringer BCD 2000 y mi portatil es de windows 7, el problema es ke los driver del controlador no estan actualizados (hechos para XP) y por lo tanto no puedo hacer funcionar...
Hola, pruebe este enlace http://www.driverscape.com/download/Behringer-BCD2000-v1.0.0.6 detecta su sistema operativo para darle el controlador correcto para su ordenador. No entiendo el espa?ol. ยก sin embargo, he traducido al ingl?s!
Jul 22, 2017 | Computers & Internet
No puedo escaner con esta impresora en Windows 7, alguien me puede ayudar por favor
el problema es que no hay controladores para Win 7. Hay una manera, es utilizando el plug & play de windows. Lo que tienes que hacer es conectarla mediante USB (en red no sirve el escaner) una vez que windows reconozca el dispositivo vete a el panel de control y busca impresoras y dispositivos y veras un icono con la impresora. Si le das click secundario tendras una opcion de escanear, tambien puedes ir a Paint y en la esquina superior izquieda en el boton azul tienes una opcion que dice desde escaner o camara
Aug 26, 2010 | HP LaserJet 3055 All-In-One Printer
Donde consigo el driver para quickcam express usb min v-uap41 logitech para windows xp pro 2007, gracias
aqui tienes compañerito =)
http://www.logitech.com/es-mx/435/254?section=downloads&bit=&osid=1
espero te sirva de algo
es el controlador del xp de 32bit (que es el mas comun)
en la pagina tambien puedes cambiar la configuracion por si lo necesitas para vista o para el xp de 64bit (si no estas seguro de tu configuracion instala el que esta directamente en el link)
saludos
Aug 12, 2010 | Logitech QuickCam Messenger Web Camera
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
Alan
Descargar el drivers de sonido para el equipo de las fábricas o sitio web de búsqueda de controladores de la tarjeta de sonido en google. Eso es todo lo que necesita. Tiene un gran día!
Apr 28, 2009 | Gateway GT4022 PC Desktop
Gateway FPD1760 17" LCD Monitor Logo
398 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
