Question about Rowenta DG-980 Iron
No steam coming out and water tank not pumping water into generator to make steam
I own a Rowenta DG980 steam generator one year and two weeks old. now it quit making steam and the water tank will not pump water into the generator I contacted the company and there offered absoultly NO HELP !!! this will be the last Rowenta product we buy . Has anyone got some advice to help resolve my problem Thank You R G Weide
  • 5 more comments
  • jeflorida Mar 08, 2008
    I have only had the iron for just over 1 year and left it alone for 5 months cleaned out and well stored, now it will not give any steam Please help I can not affort a new steam system just now ....
  • hbfix Mar 18, 2009
    How to fix the steam issue on DG980. I call Rowenta and they have service center in IL. Since the iron is out of warranty, I have to pay for shipping and then they will provide an estimate to repair. If I choose not to repair then I have to pay the shipping again. I calculate about $50 in shipping. Any way to stop the red blinking light. I followed the cleaning maintenance procedure which I clean after 3 years.
    Also when I tilt the Iron without the water reserviour, I would get the pump action but no steam. If I tilt with water reserviour then water spills but still no steam. Any help or advice is appreciated.
  • Anonymous Apr 05, 2009
    The yellow light is flashing but there is no heat being produced.
  • Anonymous Mar 15, 2014
    Carnt get any steam to come thro ... There is water in tank , steam pipe not kinked either . And it was perfect last time I used it, only switched it off and now carnt get any ..
  • Anonymous Mar 23, 2014
    Water tank comes loose during use and water pours out there is a small washer but do not know if this should be fitted to the tank or the iron
  • Anonymous Mar 24, 2014
    Steam generator not working
  • Anonymous Mar 28, 2014
    My makes a lot of noise but no steam
    Scholar:
  • 70 Answers
The Rowenta DG-980 Iron/Steam Generator works great from our experience (it is a consumer grade unit with commercial grade technology) and over 90% of the user reviews I have seen are happy with it, unfortunately it is a discontinued model & the newer replacement is not as good. Service seems to be rather thin, as is the case with most corporate entities; I was on the phone for 30 minutes before I was able to locate service center in Concord, CA (I am in SoCal), and is the only one in the state that does repairs on them, and I am going to check them out...stay tuned.
Posted on Feb 02, 2008
  • Roland Wong
    Roland Wong Jul 02, 2008
    First the good news, the service center in Concord is very good and would you believe they have new in the box Rowenta DG980 in stock! Now the not so good news. This model uses what I call a "flutter pump" that turns on when the boiler needs more water pumped in from the reservoir or it the reservoir is dry and the red light comes on indicating it is out of water.
    Generally, if you remove the reservoir and turn on the unit, in about 5 minutes the boiler should have sufficient heat and the residual water in the system has turned to steam, provides at least one or 2 "bursts of steam". It is likely the electronic ckt pc board detect circuit is bad. It enables the flutter pump to fill the boiler with about a few tablespoons of water to be converted to steam and repressurize the steam system. If the event sequence is broken you can likely determine the bad part and replace it yourself; however, the ckt board is about $75.00 (make sure you label all the connections & draw a color coded diagram before replacing) especially if the flutter pump does not turn on and everything else gets hot & steams is okay with unit less than 5-10 yrs old. A lot can be said if your unit is not that old, you have used clear water, allowed unit to run dry (minimizing long term storage with water in unit), and cleaning the boiler as specified in manual.
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
What is the best way to clean my Rowenta iron.
I always run the DG980 till the steam runs dry, unplug and let cool. Rowenta recommends using clear water ONLY. They even provide a small hose & faucet adaper to flush out the steam tank reservoir.
Since it sounds like you do not have it, the next best thing is to use filtered water (I have a 3 cylinder water filter in the kitchen for drinking water), The tank has a plug on the side which should be removed once unit is cold, tank flushed with filtered water and drained completely and leave the treaded metal plug and trim cover off to air dry completely, as well as the blue tank.
May 24, 2010 | Rowenta DG-980 Iron
My Rowenta Master Steam Generator - Steam button turns on but does not turn red or heat.
- First the good news, the service center in Concord is very good and would you believe they have new in the box Rowenta DG980 in stock!
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Now the not so good news. This model uses what I call a "flutter pump" that turns on when the boiler needs more water pumped in if the reservoir is dry and the red light comes on indicating it is out of water.
Generally, if you remove the blue water reservoir and turn on the unit, in about 5 minutes the boiler should have sufficient heat converting the residual water in the system to steam, for at least one or 2 "bursts of steam".
If all this works, then likely the $75 electronic printed ckt board driver detector is okay. It enables the flutter pump, fills the boiler with a few tablespoons of water to be converted to steam and repressurizes the steam system. It is the sequence logic this board does that you can use to determine the bad part, find and replace it yourself. There are many thermostats and sensors and without a schematic it is tough to reverse engineer.
The most expensive parts are the tank heater and sole plate elements followed by the ckt board (make sure you label all the connections & draw a color coded diagram before replacing this part) especially likely if the flutter pump does not turn on and everything else gets hot & steams is okay if unit less than 5-10 yrs old. BTW a new unit is $350 so you have to weigh your options and talk estimate for repair with repair tech if you go that route. A lot can be said if your unit is not that old, have used clear water, allowed steam to run dry (minimizing long term storage with water in unit), and cleaning the boiler as specified in manual. It is worth the price to repair OR replace. It is a great machine.
May 16, 2010 | Rowenta DG-980 Iron
I need to purchase the thermostat/steam generator that is inside the water tank of the rowenta dg050 iron/steamer. where can i find that part? i know it is the problem
I would call a Rowenta service center to find the part and cost. If you are in the US go to the After Sales Service, Service Centers at
http://www.rowentausa.com/rowenta/frame.aspx
If you are outside of the US go to the www.rowenta.com site and select your country.
Aug 09, 2009 | Rowenta Steam Generator DG050 Iron
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
Rowenta steam generator
Maybe the cap is coated with mineral deposits. Do you use ONLY DISTILLED WATER in the iron? If not, minerals from the water could be the cause. Try pouring some CLR or a similar product over the cap and see if that frees it up . If it does, pour some CLR into the iron's tank, and set it to the highest temperature setting. Run the iron over an old towel to help clean the steam vents. Then fill the tank with DISTILLED WATER and do the same proceedure two more times using DISTILLED WATER ONLY to flush out any remining CLR.
Aug 27, 2008 | Rowenta Steam Generator DG050 Iron
What should I do ?
The old Rowenta DG-980 is a consumer grade machine but with commercial quality function and features. My gal who worked at a dry cleaners many years ago loves the DG-980. Here is the scoop on how to get it going if just cleaning it is all it needs (our used one had the same problem and I fixed it by doing the following:
Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion.
To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time).
After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water and debris that was is in the system. Hope this helps :O)
Aug 12, 2008 | Rowenta DG-980 Iron
Trouble with Rowenta Irons
If your Rowenta DG 920 is chucking guff from the steam jets you need to flush it as per the instructions. ( ie. Flush every 10 uses ) If you haven;t done it for somewhile, you'll next need to expel the reamining guff with lots of steam. Then no more probs.
Aug 05, 2008 | Rowenta DG-980 Iron
I have a Rowenta DG-980 steam generator. It spits little grains of something when I use my iron. It doesn't hurt my clothing, but I have to brush the stuff off my clothes when I am finished ironing them. I...
Hi, Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
May 06, 2008 | Rowenta DG-980 Iron
Steam from rowenta preassure iron and steamer
Hi, It is likely you have too much residual water in the iron or have mineral deposits from the tap water you have been using. Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
Apr 16, 2008 | Rowenta DG-980 Iron
Rowenta DG-980 Iron Logo
1,607 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
