Question about Refrigerators
Floaties in whirlpool kitchen aid water
Clear .. kind of white slippery particles ... floaties from water dispenser...
I have changed filters... it actually makes it worse when it is first change... I think because the air presure.
  • 4,070 Answers
This is probably from the reservoir behind the crispers' in the fridge. It's a common problem and can be fixed by replacing the reservoir. They are usually replaced with a coil of water line instead of the original type. You can search for parts on line or go to an appliance parts store.
Posted on Sep 28, 2009
Why do I have floaties in my water from fridge dispenser
IF filter fitted them renew, if no filter fitted, then give dispenser a very good clean, eliminate 1 problem at a time, and see what happens.
Feb 14, 2015 | Whirlpool Refrigerators
White translucent particles in water from dispenser
Be sure the water filter is replaced.
Feb 26, 2018 | Refrigerators
I have a side-by-side ref. It use external filter. I notice that water out of filter (before going into ref) is clear but when I collect water from water dispenser of my ref is cloudy and some very tiny...
was the outside filter factory? by this I mean does the unit have an internal filter ? if no, then you need to flush the system, clean the outside dispenser components, lime or rust has accumulated on the dispenser if the water from the outgoing side of the filter is clear ( is the ice clear and fed by this same water source? if so,, its just outside build up that needs to be cleaned
Jul 03, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
We changed the filter to the water dispenser but
run about 2 gallons of water through the filter, if it did not help - the stuff is coming out the tubing between the filter and the dispenser. Check water hardness. If you have water softener, make sure it works properly.
Apr 11, 2010 | Whirlpool ED2FHGX Side by Side...
Kitchen Aid water dispenser makes a hammering sound when in use.
this is a pressure problem . some times caused by line size . but generaly changing the water valve will correct this problem . ****
Jan 06, 2010 | Whirlpool GS6NBEXR Side by Side...
White floaties
Did you flush the filter ?
Jun 17, 2009 | Refrigerators
Water filter won't come out so I can change it.
I had same prob when I changed filter first time...if it is up in the top corner of fridge, you'll need some kind of rubber gripper to use cause the condensation makes the filter holder slippery. Just grab on to it and turn counterclockwise. It should just screw out, take out the old filter, replace w/new and screw back in. On some fridges, the whole part you screwed out has to be replaced instead of just a filter inside it. Hope this helps.
Jan 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Scales floating in water
purge the water in the door for 3-4- mins. and replace the filter
May 14, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Particles floating in whirlpool filtered water.
okay - we have had this same problem for around 6 weeks - We called a service repairman to come out and he said that these "floaties" are harmless bacteria. We should disconnect the filter and flush the system by using 1 gallon of water a day (wasting it) after the chlorine in the water is allowed to build up again then the "floaties"- bacteria- will go away---- gross :-( We will see if it works---
Oct 16, 2007 | Refrigerators
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
