Question about Stanton STR8-80 Turntable
Turntable will slow down for a moment while playing causing a dragging effect in the sound of the record. Turntable hasn't been dropped or damaged in any way.
    Guru:
  • 256 Answers
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Posted on Aug 18, 2010
Hi the turntable motor on my rowe r 80 started to drag when playing a record now it has come to a stop before record is finish whats the problem? do i need a new motor? thxs David
Maybe or maybe not. Often things like grease or dirt get into the workings or the motor causing it to slow down. Sometimes the motor might need oiling.
Oct 23, 2015 | Audio Players & Recorders
The turntable on the Crosley I have just brought,spins round unevenly(up and down),is this a problem as it plays some records ok but will not play others.
The platter should be level. If it is not then it could either be warped, by oil, heat affecting in the past. Or just faulty. Even if a warped turntable plays a record OK, it could damage it, as it is so easy for a record to be damaged, it could cause a scratch on the record. It should be checked out.
Feb 23, 2015 | Crosley Cruiser 3-Speed Portable Turntable...
How to fix flutter & wow on a Gemini 500 XLii direct drive turntable
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
Jul 30, 2014 | Philips gemini XL-500 II Turntable
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
Turntable playing too slow
there is a (v.r) for speed in side look for it and turn it a little
Mar 24, 2014 | Technics SL-BD20D Turntable
I just bought my turntable about a month ago and everyonce in a while in the middle of songs it starts to slow down and drag?? the sliders r set normal it feels like the motor may b burning out or its not...
It does sound like the turntable motor is starting to fail, and it will get worse. The only solution is to take it back because there is nothing that can be done under the present situation. My advice take the device where it was bought while your warranty is in place.
Mar 03, 2011 | Numark ttUSB Turntable
Sound is dragging when record is playing.
sounds like your drive belt has stretched?
try this company
mailto:info@needledoctor.com
Apr 05, 2009 | Sony PS-LX250H Turntable
Stanton STR8-80 Turntable Logo
250 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
