Question about RCA Televison & Video
Re: RCA32'' picture tube tv mod.# F32683 SB, chassis # CTC197CE2. I need to adjust the width of the screen. How do I enter into the service mode of this unit? Can you please send me the service manual? Thanks.
  • jiro Sep 29, 2009
    Thank you very much for the helpful info.
    I was able to solve my problem.
  • 17,970 Answers
Here is a little something I put together just for you. I found a site that said some RCA TV's had the service codes on the inside of the back cover. So I pulled mine and there they were.
CTC203 Service Code Information
Parameter ------------- Parameter Name -------------- Value Range
P00 ------------------- Security Pass Number --------- V76
P01 ------------------- Error Detection Code 1 --------
P02 ------------------- Error Detection Code 2 --------
P03 ------------------- Error Detection Code 3 --------
P04 ------------------- Horiz. Phase (50 or 60Hz) ----- V00-15
P05 ------------------- EWDC (width) ---------------- V00-31
P06 ------------------- EW Amplitude (50 or 60Hz) ---- V00-15
P07 ------------------- EW Tilt (50 or 60Hz) ---------- V00-15
P08 ------------------- Top Corner Correction --------- V00-07
P09 ------------------- Bottom Corner Correction------ V00-07
P10 ------------------- Vertical D.C. (50 or 60Hz) ----- V00-63
P11 ------------------- Vertical Size (50 or 60Hz) ----- V00-127
P12 ------------------- Vertical Countdown Mode ------ V00-03
P13 ------------------- Red Bias ---------------------- V00-127
P14 ------------------- Green Bais -------------------- V00-127
P15 ------------------- Blue Bais ---------------------- V00-127
P16 ------------------- Red Drive --------------------- V00-63
P17 ------------------- Green Drive -------------------- V00-63
P18 ------------------- Blue Drive --------------------- V00-63
P19 ------------------- Gemstar OSD Horizontal Adjust -- V00-255
P20 ------------------- Gemstar Vertical Adjust --------- V00-255
P21 ------------------- Gemstar Horizontal PIP Adjust --- V00-255
P22 ------------------- Gemstar Vertical PIP Adjust ----- V00-255
P23 ------------------- Gemstar Window Vertical Size --- V00-13
Note: Stepping to 200 instead of 76 selectsthe Service Computer Mode. Must unplug unit to exit this mode.
Part No. 15358070
I also found this on the net.
5.4 GE TELEVISIONS / RCA TELEVISIONS / PROSCAN TELEVISIONS
Read the _ SERVICE MODE WARNING _ before proceeding.
To enter service mode, push and hold the [Menu] button on the set. While holding, push and release the [Power] button, then the [Vol +] button.
You will now have some information on the screen: "P0 V0"
To actually be able to change these values, you must push [Vol +] on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value.
P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual.
P4 - 7 control the horizontal size, shift, vertical size and shift.
You may also find a summary leaflet for the service tech clipped somewhere inside the chassis. The procedures for getting into the service mode, as well as the service items of interest will be there.
If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material.
Also can review this information:
- Intrepid Video & Electronics
- RCA/GE TV (CTC175-187+)
WARNING: Be aware that you modify the settings at your own risk. If you don't know what you're doing, you can really mess things up.
Good luck.
Posted on Sep 28, 2009
Horizontal adjustment
What is the brand name and model number to your TV? Provide more details please. Actually what do you want to adjust? If it is horizontal width, you have to enter its service mode to select this option. If you wish to get more details about how to enter service mode to different models of remote controls, check this link.
Feb 26, 2013 | Televison & Video
How to enter service mode for WS73615 tv
Model is a v-25 chassis which has 3 hidden menus:
Done with the original remote: Menu 2470 enter is option menu (hard reset etc.)
Menu 2457 enter is circuit adjust menu
Menu 2459 is convergence adjust menu
be rather careful in the circuit adjust menu and write down settings before adjusting there
Oct 29, 2012 | Mitsubishi WS-73615 73" TV
I have a Sylvania 6427 17
It sounds that the width of the picture to your TV is more than normal. There are two reasons for this fault. If the width adjustment data value in its service menu mode has been misaligned or the output DC voltage from the main power regulator is more than normal. You can determine which among the condition stated above is now effected to your TV
Just look at the picture. If the width and height of the picture is seem to be more than normal, make sure that the power regualtor section circuit has the fault. If the dimension of the picture is affected to its width only, [excess than normal] the data value with service mode should be checked.
Also note the position of the picture. If the picture position has moved so much than normal, ether towards left in this case, you have to adjust the picture position. Anyway, it will be best to contact any experienced service technician, since, service mode entry and data adjustment are skilled work.
Jul 31, 2012 | Sylvania 6427GG 27" TV
Ihave changed new tube on 15 inch sansuiflat tv but vertically light not totally spread
You have to ente its service mode function to adjust picture width, height etc: Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web
Proceedigs to enter the service mode are described in detail here.
May 14, 2012 | Televison & Video
Picture image does not look full when showing people
There is a service menu adjustment. I have seen several of these sets with bad components in the horizontal width control circuit. maybe your other set has a width problem. put both on the same channel. like cnn with the ticker on the bottom. what is the difference in size?
the width adj. procedure is: with the set off. use the remote, enter. MENU>5>VOL+>POWER . the set will come on in the service mode. then with the menu adj. buttons you can step threw the service menu to H.WIDTH adj. until full picture. also VERT. HEIGHT. when you are done adjusting make sure you press the mute button and watch the word WRITE flash from green to red or you won't save your adjustments.
Jan 07, 2010 | Sony FD Trinitron WEGA KD-27FS170 TV
Picture tube
no you have no vertical bad chip ic
Oct 21, 2008 | Sanyo DS27820 27" TV
Picture too tall. How do you shorten?
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Very low width and bowed verticals,no ew correction. R626 o/c
C630 (390nF, 300v) faulty, located next to scan socket. This fault can also be caused by R629 (2R7 fusable) o/c. In my set C630 was dry-jointed but not faulty. Check generally for dry joints in the E/W and PSU areas. Note that R629 is a safety component
Nov 23, 2007 | Sylvania SRT2432S TV
Can't adjust the value of the width in Service mode ' WID '
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 05, 2007 | Toshiba 55H70 55" Rear Projection...
Covergence problem
press and hold menu then push power then volume.
Aug 17, 2007 | RCA HD56W66 56" HDTV
Color Problem after replaced Circut Board
When you replace the entire board in a Zenith TV, you must make the adjustments to align the new chassis with the old picture tube. You must adjust the CRT bias and drives as well as the horizontal and vertical parameters. On the older boards there were controls on the main and CRT boards but on the newer boards the adjustments are made with the remote control after entering the service mode. Tune in the shopping channel QVC, set the color and contrast to minimum and lower the brightness until the picture is just visible. Set the CRT bias settings for a pure black and white image, then increase the brightness and contrast to get a very bright picture and if necessary adjust the drive settings so that the bright picture is pure black and white. Return the video settings to normal and then adjust the vertical and horizontal settings so that the info boxes on QVC are centered top, left and bottom. If you are not sure that you can do that right then have a qualified tech handle it for you.
Jul 23, 2007 | Zenith SY3572DT TV
Televison & Video Logo
90 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
