Question about IBM Tripp Lite OfficePro 500 (10K1911) UPS System
UPS won't charge replacement battery. When power
IBM OfficePro 500 UPS won't charge; bought a replacement battery. When power to UPS is turned off, there is no output to outlets.
  • 23 Answers
Change the chord wich is connected to u r ups..........
Posted on Sep 29, 2009
How to refill battery distilled water-exide
your UPS should have sealed batteries. If they are not you better have proper vents or the EPA will get on you. If it is a wet cell battery then stop using it. It is not made for your type of UPS
Aug 17, 2011 | IBM Tripp Lite OfficePro 700 (10K1912) UPS...
My Apc Back UPS Es 500 did not charge and then there is power when I turn on the switch. How could I repair this problem?
Good Day! Try changing the battery. please visit apc's service center for battery replacement. it will only take 3-5 working days. once done, your ups will be as good as new.
Nov 09, 2010 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
From where i can puchase the this UPS at good rates.
visit ebay.in and you can buy the UPS as desired by you at lowest cost
Apr 10, 2010 | IBM Tripp Lite OfficePro 700 (10K1912) UPS...
Apc unit is shuting itself down whenever PC unit is turned on, and then its alarm gets stuc. Also, sometimes it shuts down whenever another electrical appliance in the room is turned on. (Like a TV)
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
These lower powered and cheaper KVA type UPS are switch over types, when the mains supply fail, the UPS switches over to the inverter in milli-seconds which then supplies mains power but the power waveform is a pseudo sine wave (ie not a true sinewave. A faulty inverter circuit won’t deliver power when the mains supply fails.
Oct 24, 2009 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
The battery backup side of the APC does not work how can I fix this?
How old is unit? UPS is a Battery that is charged from power outlet.It maintains voltage when computers are plug into it so fluctuations in current don't spike or wane.On a Power Failure the UPS supplies all the power by using the battery and an inverter.If your units batteries are not charging you need to replace them.In most cases it is not cost effective.Do some more test before you replace it.Good Luck.
Sep 08, 2009 | APC Back-UPS® CS 500 UPS System
Manual
Product Details function pw(s){pop('/xWI?lid=1&fid=1647&aid='+s)} Product MPN MPN 10K1912 Key Features Form Factor Desktop Output Power (VA) 700 VA Output Power (W) 425 W Max Backup Time With Full Load 5 Minutes Connectors Total Number of Outputs 6 Outlets Outlet Connectors NEMA 5-15R Technical Features Recharge Time 4 Hours Surge Suppression With Surge Suppression Automatic Shutdown With Automatic Shutdown Audible Alarm With Audible Alarm Cable Length 6 ft. Dimensions Width 4.75 in. Depth 7 in. Height 10.5 in. Weight 20 lb. Warranty Warranty 2 Years Miscellaneous
May 22, 2008 | IBM Tripp Lite OfficePro 700 (10K1912) UPS...
How to pour distilled water into an Exide battery
Yes well first of all u hav to check out is refillable battery...
if its refillable then u hav to check out lids and open them with the help of coin and put appropirate quantity of acid...
and make sure its diatilled water not pure pure acid...
Regards
Tawseef
Nov 15, 2007 | IBM Tripp Lite OfficePro 700 (10K1912) UPS...
IBM-OP500 Battery back-up
Have you tried pressing and holding the off\on switch to make sure it toggles to "normal" rather than "charge"?
Oct 23, 2007 | IBM Tripp Lite Internet Office 500...
IBM OP500 Uninterruptable Power Supply
http://www.tripplite.com/support/manuals/manuals_bymodel.cfm?modelID=11 that is the link to the manual you need. It sounds like your UPS is not turned on correctly. You must press and hold the on switch. Make sure the AC sign wave is lit solid not blinking, the battery should not be lit as well. If the battery is yellow, that means you are running on battery, if it is red that means the battery is low.
Jan 23, 2007 | IBM Tripp Lite Internet Office 500...
IBM Tripp Lite OfficePro 500 (10K1911) UPS System Logo
624 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
