Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
How to replace the belt on a whirlpool duet washer
How do I replace the belt on a whirlpool duet washer that won't spin
  • 5,911 Answers
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 28, 2009
Testimonial: "Thanks for the info!"
    Sergeant:
  • 197 Answers
Check to see if the drum turns ok, if thats ok take the back off and fit belt to the motor spindle first and push belt on to drum spindle and turn at the same time (like fitting a bike chain) watch your hands
  • 106 Answers
SOURCE: Whirlpool Duet not functioning during spin cycle.
In front of the machine below the door you have a panel. There are 3 torx screws holding it from under. Unscrew and pull panel down & then towars you. You will see the pump assembly right in the centre big black hoses.
You need a pair of pliers & a shop-vac if you have one, or towels & a bucket. Use the pliers to unscrew the pump filter, it is white in colour. When you unscrew this water will begin to leak out; use towels or shop-vac to mop up. Do this till all the water is mopped. Remove the drain trap completely, you will find all sorts of junk, clean out completely & refit carefully, in reverse order.
Hope u appreciate this, u can rate me........
Posted on Mar 01, 2009
SOURCE: Whirlpool Duet Washer Trouble Code F25
Best Solution is to return it and buy another kind like LG or something
Posted on Mar 01, 2008
SOURCE: replacing spin belt whirlpool clothes washer
There is indeed a drive belt to the imperial 70. Problem more likely is in the 'wig-wag' unit that engages and disengages the spin clutch and the agitator drive
Posted on Sep 10, 2008
docjohn174
  • 943 Answers
hi thanks for the question this problem can be a lid switch also if the lid switch is bad , it wont send powerdown to the wig wag solenoid . the spin solenoid is mounted on top of transmission , when plunger on solenoid is activated it drops the clutch and spins , if the solenoid is bad then it wont activate the solenoid , to test to see if you have a bad solenoid disconnect power , on the solenoid you see 4 wires just the red on the left and yellow on right reverse these 2 wires plug in washer . select spin .activate washer if the washer starts to wash on spin the solenoid is ok then i would change the lid switch thanks fr the question THE APPLIANCE DOC
Posted on Sep 11, 2008
  • 662 Answers
SOURCE: Duet GHW9150P Front Load Washer: Whirlpool Duet Washer - Error F21 (What is this) ...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
How abt a nice rating for the free help? Thnks
Posted on May 22, 2010
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Tighten belt on duet whirlpool front loading washer
There is no adjustment for the belt of WP front load. If you hear loud noise when the drum is spinning because the drum bearing was loosen. If you have insurance cover tell them to replace. Else, a cost of repair is expensive.
Oct 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet Washing machine won't drain
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive or spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
May 11, 2011 | Whirlpool Washing Machines
How do you replace the drive belt on the whirlpool DUET
The following link explains step-by-step how to replace the drive belt on a Whirlpool Duet washer:
http://www.fixya.com/support/r3059652-drive_belt_installation_whirlpool_duet
This is a very simple procedure, but if you experience any difficulties, please post back and let me know. I hope this helps you.
Nov 27, 2009 | Dishwashers
Whirlpool duet broken belt
Hi, Belt Part # 8181670 The rear panel will need to be removed and you can access the belt. Make sure the belt is centered in the middle of the large puley. Once the belt is replaced, plug the washer back in and let it spin for a short period of time to be sure the belt will stay on.
please let me know if I have helped you at all or if I can assist you further.
Thanks
Vic
Jul 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer won't spin
Sounds like the whirling noise is the pump, pumping. Does it drain at all? Check the drive belt and make sure that it is not broken. This system uses a drive belt with a clutch system to agitate back and forth. The clutch system could be bad as well.
This might not be a cheap fix, these are the main components of the system
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Squeeking noise on whirlpool washer duet ghw9100lw2
replace your belt in back easy.every year if still has smell buy warranty your rear bearing is going bad."less soap plz"
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not spin
Switch plate is broken and needs to be replace. how do I open the top of the machine.
Oct 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
469 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
